motor trike voltage meter/pressure gage
l recently worked on my 2004 GW1800 w/motor trike conversion kit. During this work l apparently blew the fuse to those gages as they quit working. l have not been ablr to locate just where the fuse/s are. Are they in-line or part of the main fuse block. Can anyone help me to find this fuse and just what amp fuse it is? thanks in advance......................:wave4:
I seem to recall they are connected to the AUX power source under the left pocket. Different years use different fuse configurations. Check your owners manual. I was a little surprised MT would use that power source. Seemed a bit limited especially if other stuff is hooked up there also.
Gold rush,you were exactly right. I removed the left pocket and sure enough, the connector had came loose, simple fix to a complex problem, thanks for the heads up............
Boatpaddle
