Motor Trike Solid Axle Kit ID??
May 27, 2011
2,654
801
San Angelo
A friend of mine needs to locate the kit ID number for his trike. Motor Trike said it is located on the front of the differential. Has anyone actually laid eyes on this number and can tell us where to look?
Thanks in advance.
It is on top of the nose of the rearend.
If you can get under the trike you can wipe the top clean with a rag and hold a small mirror above the nose you can read it from below.
Don't know why they put on the top.
Hope this helps!
Hope this helps!
Thanks Wayne!! I'll pass the info along to my friend.
My friend still couldn't find the number so I had him come over and we pulled the seat and could look right down onto the top of the differential nose piece. The number is stamped right behind the input shaft collar. Easy to see and even easier when you know what to look for.. ThumbUp ThumbUp
grimpen
