A silicone based lube works well for plastic...
Good luck.
Cheers
Doug
I put just a little vasoline on mine, on the moving joints. Then moved the side with one hand and the vent with he other about two or three minutes it worked fairly easy. Had to remove the little panel on the lower to get to the insides where the moving parts are. Used a Q-tip to apply lube.
