Lower left shock mount
Dec 14, 2017
17
5
Ocala, Fl
Hi, I'm trying to replace the lower left shock mount with no luckThe parking brake bracket is blocking the lower two bolts from being removed.I tried to remove the bracket, hit it with an impact gun and the two bolts didn't budge. Way beyond red Locktite.Obviously it can be done but I sure can't figure out how without removing the bracket.Any help will be appreciated Jon
Can you apply some heat on the bolt the bolt only......That will brake/loosen the Loctite grip...
nmbr1soonerfan
