Lower pro action shock bolt tightening
Jan 1, 2012
65
7
NE Iowa
My HD shop installed the DK Custom comfort lift and 14 inch Pro Action shocks.
Upon inspecting to find the adjustment “clicker”, I discovered that the bottom shock bolt is not tightened all way.
There is a bit of slack that allowed me to wiggle the bottom of shock against the bolt when jacked up. I would assume they should be tight all the way to “pinch” the bottom of the shock.
Any assistance appreciated.
Bingse
I imagine Kevin will respond but until he does I'll say that this is normal and correct. Otherwise it would be in a bind because as it compresses and rebounds the angle changes slightly so it needs to be able to move around the mounting bolt. This is true for both the top and bottom. There are spacers included with the shocks for this purpose - so it's not locked down.
Upon further review it appears to be a bushing that the bolts go through and they are torqued to spec so assuming this is the way they are.
Never was much of a wrench turner. ☹️
Yes, the clicker valve faces out. Thanks, the "wiggle" makes sense.
The spherical bearing on the end of each shock is something you do not find on most shocks made for Harley's. It is an expensive component....cost of the bearings and c-clips per pair is $70.
The spherical bearings are one of the many reasons these shocks work so well. Normally a rubber encased bushing is what is used. As the bike hits bumps and has laterally force on the swingarm, there is deflection and flexing occurring. With a bushing this will deform and bind up the action of the shock absorber.
When a spherical bearing is used there is a smooth articulation and no binding up as the shocks are put thru their paces. The suspension is able to move up and down smoothly & fluidly, producing a much better ride quality.
Thank you, Kevin. Since I didn't see the parts before they were installed, I didn't understand the process. Makes sense now. Thanks again.
FlintM
