Looking for advice
Dec 6, 2018
21
9
palm coast
My 2018 Freewheeler was recalled because of hydraulic clutch. [ of course parts are scarce ] I would like to install an after market cable either hydraulic or not .
Any advice would be greatly appreciated. Thank you, Jim
I think you should just get the recall done. Trying to convert back to a cable operated clutch is not worth the money or the hassle.
Have the recall done, Whats the reason for a after market cable that might come back to bite you come warrteny time..:Shrug:
Thanks for the advice. I'm concerned about who would do the mechanical work.
The recall is not difficult & takes 60-90 minutes. I have got a nice ride in to check operation after the recall was completed & all is well. It also saves you the maintenance time of flushing the hydraulic clutch system with new fluid for 2 years.
If you go to the thread on the clutch recall, watch the video by John Maxwell, a HD tech, on the recall, its good information.
Thanks.jack
I'm looking to replace the cable which holds the recall part. I don't care if it's non hydraulic. I don't want the dealer to touch my bike. This is my 4th Harley and they weren't hydraulic. I don't mind adjusting myself. Owners are waiting MONTHS for recall part. I really appreciate your advice. Thanks Jim Let the dealer do the recall, if you are not happy with the way it works you can check into this
That's not a cable, it's a DOT4 brake fluid line. Due to it being a safety issue, HD has to do the recall. If they let a bike leave the dealer without the recall & there's an accident, they would be in trouble.
I had my recall done a month ago. If you work with the dealer you don't wait months.
Clutch replacement part
Had my mechanic research " Aim Light Force " . Ordered it yesterday.
The AIM unit IMO is far superior to the Brembo unit H D uses
However, if you have the AIM unit installed on your bike now defeating the HD recall you will void any warranty you may have
It is worth checking into IMO
  • Like
Reactions: MDO
I noticed again today, after my second good ride after the recall being performed, the clutch is definately engagining earlier, when releasing it. It's much closer to the grip that it used to be prior to the recall. I am happy with it.
If I wasn't such a scrooge, I would have ordered the AIM actuator too. Believe me, I considered it. The MoCo addressed & fixed the problem, in my opinion & I'm happy with the fix.
I would much rather spend the money on a rider backrest.:cool:
El Cabron
