Whats the easiest way to disconnect the running lights from the accessory switch? I want only the radio to come on not the lights. 05 ultra classic
I believe HD added these feature for the running lights to be on with the ACC position so that you could have lights showing on the side of the road at night if you had to stop for something. Kind of like the parking light setting in your car. I'm not positive of this but it makes sense to me. Ted
Yep... I do the same thing but have learned to keep the battery tender plugged in. I've got a combination of LED and incandescent bulbs for my running lights. The "added" running lights are on when the console switch is turn to the ON or ACCESSORY position. Had thought about adding the lights to the ON only so I can listen to the stereo while monkeying around but was told not to or I could overload/overheat the lighting system.
I've got a bumper with 10 LED lights that are running lights. I've been told that my blinkers are hard to see. That was proved by a car slamming on their brakes a few days ago while I was turning.
Yesterday I took the bumper off and disconnected the wire to two lights on each side. I then hooked them up to the existing blinker wire with an incandescent bulb in the turn light housing. They now work in tandem with the original blinkers and you can really see when I have my blinkers on. Those four LED lights now are dual duty, running lights and blinkers.
Just be careful if you add your accessory lights to your running mode. I'm telling you what my trike builder told me when I complained about it... made sense to me.
