license plate relocating
Sep 18, 2015
20
17
snow hill
have a 2015 freewheeler with a bumper on the rear. i want to move my license plate from the left side to the center of the trunk area. any ideas on doing this? either on the bumper or the trunk. help will be much appreciated.............:D
Relocated Plate
Here's a before & after of mine. I mounted a pc of alum 1"x 1" angle the length of my plate under my bumper using 3M two sided automotive tape. I then pop riveted 3 alum 3/8 rivets for a tight & secure install.I drilled holes in the bracket for the plate and frame before I mounted it. To light the plate I installed Custom Dynamic white tag LEDS, part # TBO1C.....$19.95 pr. I ran the wiring under the body to under the seat and tapped into the right side tailight. Good Luck!
thanks
thank you,nice post
Here's a before & after of mine. I mounted a pc of alum 1"x 1" angle the length of my plate under my bumper using 3M two sided automotive tape. I then pop riveted 3 alum 3/8 rivets for a tight & secure install.I drilled holes in the bracket for the plate and frame before I mounted it. To light the plate I installed Custom Dynamic white tag LEDS, part # TBO1C.....$19.95 pr. I ran the wiring under the body to under the seat and tapped into the right side tailight. Good Luck![/QUOTE]
Looking to relocate license plate and I need the right tail light housing without the tag attached. Any one have part # 67800332 for sale?
Tom Wallen
