Lehman Trike Parts & Info Thread
I have decided to chime in with an announcement. Many Lehman owners are having difficulty contacting the factory to get parts and or part numbers, answer to maintenance questions and general information on their Lehman Trike. Since the company is now under new ownership and many of the old employees have left, there is a lot of information that left as well. Many of the models prior to 2002 are unknown to the existing Lehman company representatives and therefor the understanding of particular parts for these models is also missing.
I have been a Lehman Dealer since 1998 and have serviced and re-built models that date back to the mid-1980's. I also have a number of wear related new parts for these older dis-continued models as well as part numbers for the ones I don't stock.
Post a question or comment and I will do my best to solve your issues.
I have a 2000 Honda Goldwing 1500SE Lehman Trike
I want to replace the ujoints.
Where can i get instructions and the parts?
1999 Valkyrie w/Lehman trike.
Can anyone tell me where to look to find out what trike I have? The bike is a 99 Valkyrie. no idea what the trike is!Bad brakes so if I need shoes....?
And where can I find a raked triple tree for this thing?
Great resource
Thank you for posting, I just bought a 96 HD Ultra with Lehman conversion and will definitely be in touch if I find I need something. :goodjob:
2001 HD FXD Renegade Lehman Trike - in dire need of parts and information -
I have a 2001 FXD Harley Davidson Lehman trike (Renegade) and am in dire need of rear brake cylinders or rebuild kits for same. Any hope?
rear u joint
Jim
2002 Harley Davidson FLHTC Lehman Trike right side cover.
I'm looking for a side cover for a 2002 Harley Davidson FLHTC Lehman Trike. Lehman says they don't make them anymore.
Lehman made two different style side covers for the Renegade conversion. There was a 2 piece cover that had a removable front portion on the earlier Renegades and then they used a 1 piece cover (lovingly referred to as Elephant Ear). Later years they used the stock cover. Which side do you need and what kind do you have ???
Hi
I need an axle bearing for right side axle.
Do you have those and how much are they?
Lehman was developing new drive axles and brake systems between 2009 and 2013. The model you have may have had 2 of the 3 styles. If you can attach a picture of the axle housing, or a picture of the axle removed I might be able to help. PM sent
View attachment 49300View attachment 49301
Will these wheels interchange with 1500 goldwing
what is price of 9 spoke Grand National
Congratulation on the Tee Shirt win !:clapping:
The wheel hub (2 piece) would have to be machined to accept your speedometer drive and bearings. The hub might be a couple hundred dollars and would need a donor wheel doing the machining.
They make a nice dressup kit for the GL1500 front wheel that I have used that closely matches the GN (9 spoke) wheel.
http://wingstuff.com/products/19-ch...es?context=gold_wing_gl1500-wheel_accessories
Thanks, not many things in life are FREE!
Thanks for quick response. Have seen the Lazer Accent Spokes. They look great with Tri Color Ring Of Fire. That sounds like my best option Have a great day
Trying to find parts for Lehman Monarch II
I've got a 2008 Goldwing 1800 with the Lehman Monarch II trike kit. Any ideas on where to get parts for the rear axle, need park brakes, axle bearings, disc brake pads, and seals.
Welcome to Trike-Talk ...:wave4:Hill i can't help you on the parts you need, But i'm sure someone will chime in with the help you need.....Again Welcome......:wave4:
Boatpaddle
