Lehman Trike Parts & Info Thread
I have a 2002 Goldwing with the Lehman trike kit..I'm looking for a trailer hitch..If anyone has one for sale..please let me know...
Is it a Monarch or a MonarchII ??
When was it converted ? The Monarch has a trunk door that opens down.
Ford differential bearings for Lehman trikes
The bearings for the Ford differential that was used in Lehman trike are not available from Ford. That Ford differential was from a Pinto, Bobcat, Monarch etc. I had to replace all the differential bearings in my 2000 Goldwing trike with a Commander kit on it. The trans shop had to hit Bearing supply houses for bearings. They were able to match those bearings and re-do the differential. I do not know when Lehman or Champion quite using those Ford differentials
Actually, anyone who needs bearings can go to a bearing house to get a match for those bearings for any of the differentials used in Lehman trike kits. Much cheaper at Bearing houses.
mcMaster Carr is a pretty good source also.
Service Manual/light bar
I am new to this site and to the trike work in general. I recently purchased a 2007 Suzuki C90 with a Lehman trike kit installed on it. I have always done a lot of my own maintenance so I am looking for a copy of the service/repair manual for my trike. If anyone has on, electric or paper, I would be glad to pay for a copy.
Also, I am looking for light bar suggestions since my trike had a fairing installed on it at the Lehman factory.
My email is stanley175@verizon.net.
Thanks in advance for any help.
Wayne
Reverse gear
I have decided to chime in with an announcement. Many Lehman owners are having difficulty contacting the factory to get parts and or part numbers, answer to maintenance questions and general information on their Lehman Trike. Since the company is now under new ownership and many of the old employees have left, there is a lot of information that left as well. Many of the models prior to 2002 are unknown to the existing Lehman company representatives and therefor the understanding of particular parts for these models is also missing.
I have been a Lehman Dealer since 1998 and have serviced and re-built models that date back to the mid-1980's. I also have a number of wear related new parts for these older dis-continued models as well as part numbers for the ones I don't stock.
Post a question or comment and I will do my best to solve your issues.
Hi, Lee
I have a 2012 HD Ultra Classic with a Lehman LLS Renegade Conversion.
Prior to the conversion I had a Champion Reverse gear fitted, and had no problems with it.
Since the conversion, When I first start the engine and its cold, it goes into reverse perfect, but once the engine is warm like after 10km every time I try and put it into reverse it crunches something awful, I am concerned about doing serious damage to the gear box.
Do you have any ideas.
thanks for your time.
when that happens try putting it in first or second gear and then back to neutral and then put it reverse, I think maybe the trans gears are still turning and just need the extra to stop then before shifting to reverse, let us know what happens
I need your help Lee. Champion will not answer my emails. I need the part # for 2010 Champion rear axle bearing. Suzuki with VW brakes. I replaced the rear seal but I'm told I need to replace the bearing as the rear end oil washed out the sealed grease in the bearing. Just a matter of time before it goes. China # 206 comes to mind if my feeble memory serves me correctly. Inter race is slightly raised. Not level with outer race. McCarr-master shows a #6206 metric double sealed but the inter-race is not raised.
Cavie,
When you had it apart did you get a number off the bearing ???
I have no diagrams or parts index for the Champions and would rely on that number as replacement. Sorry........ Don't buy a Chinese replacement if you can avoid it.
Hi, Lee
The conversion should not be causing the problem, but the adjustments made might contribute to it. Below are the operating instructions for a Motortrike reverse gear. For the life of me, it is an exact knockoff of the Champion. Read it and see what happens.
You might have a improperly adjusted manual clutch. But that usually makes neutral (N) light hard to get.
http://www.motortrike.com/docs/HARLEY REVERSE OWNERS MANUAL 07-08 6 SPEED_REV-.pdf
Clutch adjustment non hydraulic
Loosen slack adjuster on clutch cable so that lever will travel to grip without disengaging clutch. remove derby cover and loosen 11/16" nut that locks adjusting shaft to pressure plate. Using an allen wrench, back out the screw 1 turn so that there is no binding and then turn the screw clockwise until it bottoms out. Check clutch lever to make sure it still has plenty of travel without disengaging clutch.
If you have lost all lever free play, gain more slack with cable adjuster. Once you have bottomed out the screw, and still have free play on the lever, back off the allen screw 3/4 of a turn. Now without allowing the allen screw to move, tighten up the 11/16" jam nut. Use the cable adjuster to remove the slack until you get the desired amount of slack.
Two pictures below show a 6206 in 2 different configurations. The one without the raised inner race uses a spacer shim to make up the difference. I think they added the shim so that manufacturing would be simplified. I noticed that Champion sells a kit that includes 4 pieces. Picture is not representative of item.
http://www.hellotrade.com/champion-trikes/solid-axle-rear-end-seal-kit.html
The 1st picture is the correct bearing. The kit shown in the link is not the correct parts. My bearing is double sealed. Spacer/retainer is about 1" wide. Seal protector is not shown. It is a dome shaped piece of plastic with holes in it. Mine seems to be ok. I will contact them to discuss. Thanks.
You didn't answer my question. Did you get a bearing number when you had it apart ? I also explained that the pictures of Champion didn't represent the real thing.......
As stated in my post. China # 206 comes to mind if my feeble memory serves me correctly. I believe it was 6206 china. Bearing house had no idea because of the inner raised race.
I always put it into first before reverse, and when it crunches I put it into second, it helps but only 2 in 10 times. would adjusting my clutch help.
Question: You put it into 1st, then reverse, and then into neutral before backing up ???
Should not grind......... if you are sitting still...
I start in neutral, pull in the clutch lever and put it into first, then without releasing the clutch lever I put it back into neutral, then put it into reverse,and thats when i am getting the crunch.
OK.. That sounds like a clutch that might need adjustment. What weight oil are you running in the primary ? What weight oil are you running in the transmission ?
I have no idea what weight oil is used, its gets serviced at my local HD dealer. But as trikes are not common here in Australia the HD mechanic said he could not help me with the reverse. My friend has a Motortrike conversion with the same reverse and she is having the same problem.
I don't know if Harley is using the 20-50 in your transmission or not. I suggest 75-110 in your 6 speed. But before you change any fluids, try adjusting the clutch like the video shows... If it works for you, then do it to your friends bike....
Ok mate, I will give it a go, cant watch the video yet as i am at work, and everything is blocked. I will let you know how I get on. thanks for all your help.
Just a thought. If I put it into first keep the clutch engaged then into reverse, then into neutral would that work. or would I damage my gear box.
Boatpaddle
