Issues installing Phase 7 passing lamps
Jun 30, 2013
1,000
351
Texas
Texan
Finally cracked open the coin purse and bought a set of TruckLite's Phase 7 lights for my '13 Tri-Glide. Headlight was plug and play although I do have issue the way it protrudes out about 3/4" past where the stock light did. Guess headlight rims are in my future
My problem is the passing lamps are plug and play as far as the wiring BUT the plug on the TL is very big. The bulb will not fit in the housing with this big a$$ plug. Getting ready to re-wire the bulb but thought I ask first.
I know I'm not the first to have this issue.
o~\o
Unless TL has changed something they should be plug and play. They went into my 2011 passing lights without a problem. I read a lot of posts on these before I bought mine and nobody mentioned that being a problem.
Had them on my '10 Ultra and my '11 FLHR, no problem with either. I think you had to maneuver it a bit to get them together though.
Okay, guess I'm just have to take a couple chill pills and take another stab at it.
Thanks.
o~\o
I have installed them on a 2011 and a 2012 Street Glide with passing lights installed. No issues.
I tried everything in the book. Finally cut the plugs off and wired 'em in. Lookng at these plugs you think they'd fit with a bulb. Plus TL has about a foot of wire on their bulbs that you have to wad up in the bucket.
o~\o
dhinzman1
