DK Custom Products
Sponsor
About a week ago a fellow Tri-Glide Rider was talking to me about how his rear brakes did not work very well. Specifically, no matter how hard he pushed on the brake pedal they did very little to slow him down.
He did not believe his rotors or pads were glazed or greasy. It just seemed that he pushed Far harder on the brake pedal than he ever would on a two wheeled bike, and it resulted in very little stopping power.
I have read of others that have had similar complaints.
My experience has been that the rears brakes, while needing substantially more pressure on the pedal to work, have always worked very well.
I suggested that he go 20 miles per hour (on a deserted road) and push on the pedal as hard as he could. This should lock up the back tires. If it didn't, then something was definitely different than what I have experienced on my own Tri-Glides ('11 & '14).
The day after I spoke with him I was riding and decided to do a little test.
(I should have taken pictures, and I may do it again and get photo's)
20 mph, let off on throttle and pushed brake pedal hard....rear tires locked up.
Sped up to 30 mph, let off on throttle and pushed brake pedal hard....rear tires locked up.
Sped up to 40 mph, let off on throttle and pushed brake pedal hard....rear tires locked up.
Sped up to 50 mph, let off on throttle and pushed brake pedal hard....rear tires locked up.
I thought about doing it at 60 mph, but was already smelling all the rubber I had already taken off my tires.![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Conditions-
Dry asphalt
Straight level road
I did not notice any brake fade, even though I was doing this one right after another. Probably because I was going from no brake to lock up. That would not generate as much heat as the brakes being on lightly for an extended time.
There was no fishtailing, Trike stayed straight while tires locked up.
Coming from two wheels, I primarily use my front brake for slowing/stopping. I only add the rear brake if I need to slow down faster than usual.
Prior to my little test I was happy with my rear brakes on the TG, now I am even happier with them, knowing that I can brake as hard as I want with the rear brakes, even at speed, and they will slow me down as fast as the tire traction will allow.
Conditions-
Dry asphalt
Straight level road
