How to stop the rattle in the front end.
sorry,, just joking,,,,,i know, that rattle will get on your nerves,,,,check ur fender etc,,,,or what happen to me was in the dash, a nut or screw,,,anyway when i toke off the dash one day something fell and since then no more rattle!
just give you some hint!!🤷:GL1800:
I don't have a front end rattle, but when I drive over a bump or large crack in the street I sure have a 'thug' sound from the front wheel area. Sure bugs me. Anyone else experience that?
Lower your front shocks by one click each and go to 38-40 psi in the front tire. It will help a lot !!
Tomg
TOMG I can see you are not haveing the same noise STALL and I are having. Did the shock and tire some time ago. If u shake the caliper rod like on mine there is no doubt that is where the noise is coming from. Not trying to find it anymore. Just stating if you have this issue two rie wraps did the trick on mine.ThumbUp
Thanks Heart, that might do the trick. I'll try and get to that today. ti-rouge, here I thought I was going to have to get the owners manual out to figure out where that rear pedal was!
Has anybody with the rattle tried to adjust the rods to take out the slack??
And I was more talking about the jolt of hitting bumps/manholes to adjust the shock and tire.
Tomg
Roger71!!
