Horn Switch
Jul 25, 2015
30
7
Culpeper, Va, US
Looks like I need to replace my reverse/Horn switch, does anyone with a parts manual know the part number? It is a 2015 Triglide. Horn works for push or 2 then stops and won't work again for rest of day. Sometimes goes week with out working, then works for 1 push. Checked at horn, no voltage when switch pressed. Just need a part number so I can order one online.
Jeff
Have you been in tHe rain lately? Reason I ask, myself and a riding friend got caught in a havey rain storm, horns quit working on both of our bikes, his a SG and mine a TG...mine was replaced under warranty, he bought an air horn.
might be the horn and not the switch
Horn
I checked the wires right at the horn, when switch was pressed, it still showed 0 vdc. The only thing left is wires and switch.
If I'm reading it right, Its part # 17500135 Switch pack......Around 2 hundred dollars...:Shrug:
Try spraying some electrical contac cleaner into the switch. Might cure it :Shrug: Just make sure it's capatable to plastic.
If I think of it, I spray and work all switches with silicone spray 2x a year. Just a thought.
I would talk to my dealer. The left hand module on the 2015's were failure prone. Mine started doing all kinds of weird stuff while I was on vacation in Montana. Made it home and they replaced it under the MOCO warranty. Even if your warranty has expired I would think a good dealer would work something out for you.
Weird
Thanks everyone, so weird, started working in the morning and has worked last couple days. I am suspecting dirty contacts now. Going to get some cleaner and spray the switch down.
2011Spyder*
