I need some help, I'm trying to remove the battery cover from my 2013 trike but can't figure out how to get the cover completely off,so I can remove the battery. Thanks for any help.
The cover over the battery has two screws facing the rear, and appears to be hinged facing forward which doesn't lift high enough to remove the battery, this is the problem I'm facing ?
I know this is a little late, But if all you what do is just charge the battery, Put a pig tail connection on Then you won't have to go though that grief again..:Shrug:
