HD's new 131 cu. in. Crate Motor
You can put a 131 in a trike. The set up from HD works at sea level. My house is at 7,100ft, hence a different cam, and staying with the 55mm throttle body. Power Vision required as the SE tuner won't allow enough fuel. Used the map from a two wheeled build. Even then the map had to be sent to Dyno Jet so they could make it work with a Trike. Estimate (based on dyno runs on similar two wheel'd builds) is 140+lbs torque. Build was matched to existing V&H pipes that were on the trike. Passing on two lane highways no longer a problem.
Trike has DK Custom Products oil cooler and Mighty Mite fans.
Chuck
Chuck,,,,,,,,,,'Welcome To Trike-Talk........:wave4:.....
Chuck
What year trike
Eddienorman
