I just purchased a 2013 Tri-Glide and have only 250 miles on the 103" motor. My question is, I have a 2012 120r Crate motor that I removed from my 2008 Ultra prior to trade-in and am considering the installation in the Trike. In the Ultra, the dyno numbers were 128tq/129hp, and I don't know whether that would be excessive for the Trike.
For those of you that have had any experience with this configuration, have you had (or seen) any problems with this much power in the Trike - i.e. problem keeping the front wheel on the ground, braking things, etc.? If I go ahead with the installation, I plan to upgrade the clutch to an variable pressure plate (AIM) which I had in the Ultra but left it in the 2008 when trading it in.
Also, should I possible change the compensator to the SE Compensator?
Any advice from experience will be very much appreciated.
Thanks,
Roger
Thanks,
Roger
