LED card does not plug into a bulb base. However, our Hannigan trike has an exposed connector inside the fender. Would be good to check connector contacts and waterproof the entire connector with tape, if nothing else. FYI, recall our taillights blink as well. Believe it is a refresh of the LED's.
I don't think it's electrical. One of your brake sensor switches may be set too tight. There's a manual adjustment on the front brake lever under the reserve toward the front. Don't know where the rear brake on a Hannigan is, but it's there somewhere around the reserve.... Also thinking the spring on the foot pedal may be weak and the weight of the pedal causes it to bounce??
