Grabby clutch
Phu Cat
2250+ Posts
Oct 4, 2011
2,235
1,841
Ocala, FL
Jim
When pulling away from a stop, the clutch grabs when the clutch and steels are getting close to being matched up in speed. It's at it worst when the engines really hot. I've adjusted the clutch by the book and a few ways I've developed along my many years in the saddle. Even took it back to the dealer and let them adjust it. They don't seem to think there's anything wrong with it. Does anybody elses clutch grab when it's close (80%?) to being hooked up? None of our earlier EG's had this problem.
PC
You have a 2012 if memory serves. How many miles on it?
What primary lubrication are you using?
Detail how you adjust your clutch.
Do you adjust the clutch cold or when it is warm?
I have a 2011 triglide that has done that since new.Most often when it is hot.I have had three different dealers take it apart & say that they could not find anything wrong.Clutch has been adjusted numerous times by 5 or 6 different dealers.I use formula+ in the primary.I have had the dealers document the work that they did,& hopefully if it breaks down,down the road Harley will do the right thing!!!
2011Spyder*
