- Thread starter
- #21
Not circuit breaker...
Got the trike back today. Bad reverse motor. The circuit breaker was the first thing I checked. Don't use the reverse a lot, just mainly to back out of a parking space (10 feet or so). Never use it to back up an incline. Just poor quality on Harley's part.
Do everything you mentioned except adding a little throttle ti increase current from alternator. Thanks.
The other issues were: locked up front brakes left me stranded, fogged up speedo cluster replaced, tilt angle sensor was defective and left me stranded. paint on trunk lid was cracking. Local Harley shop took care of all issues under warranty. We're getting to know each other well
Hi, you've probably already tried this, but my reverse stopped working, and it is a simple circuit breaker and toggle reset under the seat, under the right side panel. Hope this is all you need to get it working again!
Wife and I are on our 3rd and 4th Trike. 3 Tri-glides and a Freewheeler. We have never had any problems with the reverse. We have ridden 2 wheel Harleys for many years, and do our best to not park where you have to back out, so we rarely use them. Some advise, DON'T use the breaks when backing. Release the button and let the trike coast to a stop. DON'T stab the back-up button. Push it, hold it until you are done backing, release it and coast, then stop. DON'T back up long hills or driveways. go forward, and let gravity back you down. When backing, give it a LITTLE gas, this raises the voltage from the alternator and helps the reverse motor. Look where you are going to park, and do your best to park where you won't have to back out. Always try and let gravity back you up.
If I'm not mistaken, the Can Am's use an electric reverse too, so you may have the same problems with them.
I weigh 245 pounds and my '09 Tri, and '15 Free have only popped the breaker once. Wife (130 pounds) never tripped the breaker on her '11, and only once on her '14.
Good Luck, hope things work out for you
What were the other three service issues?
