front wheel bearing honda vt750ca with motortrike roadhawk rims
i think my front wheel bearing may be going wobbly and i was wondering if anyone here might have the proper bearing measurements for the roadhawk aluminum front rim on a 2004 vt750ca shadow aero i have heard stock front wheel bearing doesnt fit and my trike is my only transport so i was hoping not to have to take the wheel off until i have the bearing to replace itsinglepg_wheel_hidden_roadhawk.jpgthank you
Re: front wheel bearing honda vt750ca with motortrike roadhawk rims
that pic appears to be a rear wheel. Front wheel would not have a hub cap??? Front wheel would be stock bearing unless the bike has a custom front end. Front bearing should be stock Honda 750.:confused:
http://www.cheapcycleparts.com/oemparts/a/hon/5053fa66f870021c54be9471/front-wheel
Yep. "Should" be a stock Aero Wheel.
Above is a link to Cheap Cycle Parts. They sell OEM Parts a lot cheaper than the Dealer if you can wait for shipping.
Bought from them many times without issue.
Otherwise, the Exploded View Schematic (of a Front Wheel Assembly for a 2007 VT750CA) also reference Part #'s. Might be able to use those and cross-reference to get specs.
Good Site to get those Schematics for all Parts inquiries in general as well.
Hope this helps and you get the issue solved quickly and mobile again.
it is its the only pic i could get off the motortrike site of the roadhawk style rim
How many miles on the bike?
Does it have a rake kit?
Have you jacked up the front and checked the wheel for looseness, checked the forks and the head bearings?
Yep.....Stock Bearings and Axle from Motor Trike even if the Stock Wheel was substituted with one of Their Aftermarket Replacements.....I checked Mitzie's when She had one and I was installing Raked Trees on it.....ThumbUp
Tom Wallen
