I'm looking at installing an external breather system such as the one you have on your 2014 Tri Glide. I have a 2016 Tri Glide, which external breather system kit are you currently using and would it work on my 2016? Photos below of my Screamin' Eagle Ventilator.
To the OP, on my 2009 Electra Glide Ultra Classic I had a external external breather system similar to what Fearless is running and I had a catch can on the right down tube.
I would drain the catch can every month.
I used RTV to plug the holes filter where the stock breather hose went, never had any problems.
With my 2016 Tri Glide I'm thinking of going with a setup like what Kevin is running, looks very nice.
6bull aka Jim
6bull aka Jim
Below is not a photo on it with the Rushmore cover, but it would work the same (less of the hose will show with the Rushmore).
It stays stationary, and will not bang around. (I have close to 20K miles with this set-up on my Tri-Glide)
Here is a photo of where Jim put his, below the right side cover-
For a long time I ran mine below the rider floorboard. It is completely hidden, unless you're on the ground looking up. There is plenty of room inside the floorboard bracket to route it there easily. That is where Devin runs his on his Street Glide also. I looked around for some photo's, could not find any. But if you look at the space between the frame and your floorboards, you will see there is a lot of room there.
