Dyno Results
Jul 11, 2011
131
2
Fremont, Ohio, USA
Got the Triglide back on Thursday from Roeder Racing in Monroeville...all I can say is WOW.... Here are the before and after numbers... 61.06 HP before...75.22 HP after 75.57 torque before....98.55 torque after.
Here is what I had done: Roeder Full Tune Dyno... Screamin' Eagle Heavy Breather Performance Air Cleaner Kit (Compact Design) removed the Cat. ...Roeder Racing Custom header and Mufflers....
It took 2 weeks to book the Dyno and they had it for 3 days.
Have put almost 150 miles on it and will check the gas mileage in the morning. It runs like a completely different Trike.
ThumbUpThumbUpThumbUpThumbUpThumbUp
Same reason you down shift to get your trike to move easier. The ratio in 4th will have more torque to power through than 5th and the same reason for 5th to 6th
Ok thanks. So what is the proper gear? Do dyno tuners like to run in a particular gear to get higher numbers?
The majority of tuners run the bike/ trike in 5th gear.
:Agree: Its amazing how much power and torque a 6th gear run kills on the dyno. When we had mine on the dyno I wanted to see what a 6th gear run would do. It kick the crap out of the power and torque in the neighborhood of 8/8.
WOW, that's some really impressive numbers for those mods....especially that useable torque increase....CONGRATS....ThumbUp
Thks Skuuter.... the wife and I are like kids with a new toy. We spent the entire weekend riding. So nice to have some butt to pass someone doing 60 mph. I do have to be careful twisting the throttle when cops are around...it does roar a little... :D...
Now I have to pay for the 10 day Princess cruise I promised wifey if she let me get the work done on the Tri glide.... Hmmmm wonder if I could take the Tri glide along...:D:D:D:D
^^^^^^^.....:laugh: :laugh: :laugh:
It's just money, right?
Yes, real old thread revived, but this is about dyno results. Right place?
Last August I had the 120ST put into my trike, and I never really thought it ran like I thought it should. It just wasn't "crisp". Also, it started to idle real high, 1,500 or so. The HD shop that installed it couldn't dyno trikes and used PV to tune with. Later, I went with the Target Tune hoping for better results. I was also getting 18/19 mpg. I found a trike dyno about 140 miles away and got it back today. (Urban Custom Bikes in Fife, WA)
What they found were several contributing factors to poor performance; slightly bent and leaking intake seals in the throttle body, and in their opinion, too small of fuel injectors. They installed the 42# Siemens deka injectors and new seals, then dynoed. They said one cylinder was lean, and one was rich. The AFR at idle was 17.
Yeah, I knew it was bad, and the before was just 72 hp & 76 tq.
The after was 88 hp & 104 tq! If trikes do lose 15-20% compared to 2, that's a still pretty good number.
I didn't have more than 10 miles on it before dark and cold, but what a difference! The graph shows the tq is about 90+ starting at 2,800 rpm, and 100+ from 3,000 - 4,400 rpm.
Now I hope my mpg will increase too.
Can't wait to get on it again during a nice day. Sure feels good to have that "right" - finally!
3rd wheel, I have a 2013 Trike that I put a 120r motor in and have sense changed a few things that I think puts it closer to the 120st - i.e. T-Man 577 cams, roller rockers, beehive valve springs, Smith Adj Pushrods, bronze valve guides and a 55/58 TB by HPI. All of this makes the Trike have much better street manners and I get about 35mpg two up and about 32 -33 solo, go figure!!?? Also have the Target Tune and love it.
Your 120st has the SE 259E cams which are pretty close to my T-man 577's. I really like the set-up I have now, much better than the OEM 120r crate motor!!
Ride safe, keep the front wheel on the ground!! :)
Roger
Roger, did you get yours dynoed after the rebuild? Just curious of other trike numbers. On the CVO website, a person with a 120ST dynoed a 2 wheeler at 125/137 with no other changes. Pretty strong engine for stock.
3rdwheel, no I did not get the Trike Dynoed with this motor as there is no Trike dyno anywhere close to Central Oregon where I live. However, I did have the 120r dynoed when it was in my Ulta (two wheeler) and it was about 130/130. I don't even know of a Trike dyno in the whole State of Oregon!
However, I am very happy with the motor performance as it is now. I am running the PV/TT tuner and received my initial map from Jamie @ Fuel Moto and have done some TT/AT's and made some minor adjustments via WinPV and everything is running smoother. Via gauges on the PV, I monitor sensor info on CLI, AFF, F&R WBO2's, Set AFR, MAP, engine temp and RPM. This provides sufficient info for me to monitor the running condition of the motor.
The way it is running at present, I doubt that I would put it on a dyno if one was available.
Roger
Jurgen0419
