Well , Kind of , The original plan was to rewire the Passing lamps and turn signal lights on the bar.
I bought a 2008 Road King Passing Lamp Bar from Marketplace to rebuild and use on the Freewheeler. I wanted to use the turn signal lights on the bar but, they hang down in front of the original turn signals and touch them. I did not want to take off the OEM lights because I am not sure if I could get a cover to hide the holes left by the lights. So , I decided to take off the turn signal lights on the bar and I am the process of fabricating flat pieces to cover the opening where the lights were.
There was a mod I had to make for the passing lamps: When I installed the passing lamps I noticed that the lamps had some movement, so I removed them and used Tacky Tape half way around the passing lamps behind the ring. This gave a good waterproof seal and the lamps were in tight.
The wiring: I went to the Harley dealer and asked for the correct connector for the accessory plug under the tank, He gave me the part for one under the right side of the bike.
The correct place to install the wire for the passing lamps is on the left hand side of the bike by the fork , the bottom connector pin 5
(blue black stripe) there is also a hole for a switch in the back of the forks
