thank you trike LadyThis info might help you: https://img1.wsimg.com/blobby/go/196ab735-e9c7-46e6-bb49-a914633cbdf3/downloads/Cobra & CobraXL Trike 1-20.pdf?ver=1721935671382
The last page has the wiring diagram.
Also in this pic on the right handlebar I have identified a switch
It seems to do nothing. Im wondering if this is something added from CSC or something that a dealer has done?
ironhorse54 and I just checked our 2021 DCT’s with the CSC Encore conversion (converted in October 2023) and the backup lights came on both bikes when the reverse switch was pressed WITHOUT the bike moving.
This info might help you: https://img1.wsimg.com/blobby/go/19...ra & CobraXL Trike 1-20.pdf?ver=1721935671382
Yeah it is active in the box I just can’t find where it goes without taking all the covers and fareings offOops, I just reread your post and my response. On the right handlebars, that whole row of switches above the brake master is an aftermarket add on. It's used for adding different aftermarket wiring to control many different functions. It's quite possible that the far right switch was never connected to anything. You may have to open up the top and inspect the wiring to see if it is even wired. If it is, there's no telling what it is supposed to control and you would have to trace the wiring.
