Well it's been great weather for riding, sorry all you northerners, I've put about 400 miles on in the last few days. I have found a couple of problems first is the trunk release, it will not lock. The latch will not engage, not even if you just push it with your finger. Then I have a crack
above the gas peddle area where the inside black meets the colored body, pictures to follow. I was just sitting and watching boats in the bay and had my feet resting in the empty area and noticed the crack.
I did find a way to solve a air leak with the suspension, run the pressure up to 90lbs., then down to 35 and what it does is reset the check valve. I got that from a fellow down here who "test rides" for the factory. He is on his fifth Stallion.
