Code P2135h
JTJersey
800+ Posts
Gold Member
Jul 2, 2021
985
1,253
Millville, NJ
John
My '21 Freewheelers check engine light came on today on my way to lunch. Turned around ( :mad: ) and found code P2 135h. Something to do with my throttle sensor. Did NOT clear the code. Restarted the trike and went to lunch. No check engine light reappeared. After I got back home I went in to clear that code, but it indicated there were no codes. Was this a phantom code that disappeared miraculously?
Possible, have you recently washed your trike or rode in heavy rain?
If the code comes back, unplug and clean the wire connector pins @ the throttle actuator
The code can be an interruption of voltage at that connection
Of note the H at the end is a Historic code
They can after 40 start cycles clear themselves
It also means that the code was setting prior, the ECM saw something it did not like over a period of time
That code was lurking in the background for a time, the voltage signal was out of parameters, but is no longer
If it comes back on a deeper dive into diagnostics will be needed, for now I would for sure unplug the connector, clean the pins on both the male and female pins and apply a little dielectric grease and ride it
I had that code on my 15 Freewheeler coming back to FL from Mn
I was riding on the tail of a tropical storm on I 75, the rain was torrential
At 1 time the engine sputtered right before the CEL light came on
When I stopped in Lake City Fl I knew right away what the problem was
I always carry some cleaner and dilectric grease, so I did the clean and relube
Never skipped a beat after
Possible, have you recently washed your trike or rode in heavy rain? If the code comes back, unplug and clean the wire connector pins @ the throttle actuator The code can be an interruption of voltage at that connection
Closest she's ever been to being in the rain was road spray and light drizzle coming back from FL. Hmmm, can I blame you? :D
I saw by your second reply that the H means it's an Historic code. I've never experienced any riding problems such as you described so I have no idea why it would have reported that, but then I did get a check engine light before my 10,000 miles service that indicated a Lost Comm with ABS. Cleared that and it's never come back. The service dept checked for it, but found nothing wrong and charge me $120 labor because it wasn't a warranty issue. I think I'll just keep an eye on it for a while. Thanks for the tip.
Are these the connectors your referring to?
No, the ones @ the Throttle body there should be a plug in, similar to this
Look at the picture you posted, see the 3 screws @ the left, look below to the right, that is where the wires would plug in
No, that is the intake temp sensor
The throttle plate sensor ( that receives the input from the TBW from the twist grip) should be either on the bottom of the induction module or the side of it
Jurgen0419
