Cobra Fi2000R Tuner
Aug 21, 2011
769
14
Lake Murray, SC
Pete
Is anyone running the Cobra Fi2000R fuel injection tuner on their trike? If so how is it working for you and what has it done for your trike? I have a 2005 Ultra/Lehman with an 88" motor that is completely stock, what results should I expect? I would like more power and cooler running. Thanks in advance for your help.
What I understand is that the more simple fuel tuners, like the Cobra unit and the Fuel-Pak, have limited capabilities. This is okay for someone doing a basic tune for intake, exhaust and maybe a mild cam. I have used Fuel-Paks on several HD's configured this way and found them very easy to tune with satisfactory results.
However, for my last 2 HD's I choose to install the PC V units which offer awesome, wide range tuning parameters and are suitable for upgrade to an auto-tune mode with wide-band O2 sensors. I am extremely happy with the new PC V units and if I make further changes to my engine later on I always have the option to custom tune the PC to match my new upgrades.
My most recent PC V install is on my 2011 Tri-glide which has an SE intake, a gutted head pipe and a set of 4" RC mufflers. This trike, in stock configuration, was anemic in power delivery and had a nasty tendency to ping at highway speeds under light load. Now, it truly operates like a different engine, with strong pulling power from 1st thru 6th gear with not a ping to be heard.
Whatever you decide, do your research cause they all have their pro's and con's.
Good luck.
R
Thanks Rich. I don't get e mail notification when a post is made to one of my subscribed threads and I had not checked this one out since you posted.
I installed the Cobra on my 2007 flhtc trike and do notice a slight difference in performance but not a awful lot. I did notice I got better gas mileage and that was a plus but I don't think it helped much with the cooling. if I had to do it again I would spend the money on engine performance like cams, etc. etc.
wzejda
