marshall
30+ Posts
Is anyone having a problem with low cb volume. I can’t seem to hear my cb very well compared to the rest of the things like gps and apple CarPlay.
I had the same problem and some things to try are, adjust the speaker to the center of the ear, turn the squelch down till you can hear the rush noise and then try turning up volume on helmet, go into settings on bike and make sure the volume is wide open all the way up you can also do this while the CB is active. What type headsets are you using?
Yes, and I have it set at 20, thanks Marshall
Bad antenna ground strap. Thanks for all the help.
Marshall
