CB Volume
marshall
30+ Posts
May 10, 2010
34
15
Hoschton, GA
Marshall
Is anyone having a problem with low cb volume. I can’t seem to hear my cb very well compared to the rest of the things like gps and apple CarPlay.
I had the same problem and some things to try are, adjust the speaker to the center of the ear, turn the squelch down till you can hear the rush noise and then try turning up volume on helmet, go into settings on bike and make sure the volume is wide open all the way up you can also do this while the CB is active. What type headsets are you using?
I know you said everything else comes through fine but if it is the speakers then you will just have to turn the rest down after you adjust them because the CB just does not have the volume everything else has, and another tip if the CB is receiving a signal either from someone transmitting or because the squelch is to low the other volumes will not operate on the bike. Oh and try talking to different people I ride with some that do not come through very well and others that come through just fine I use my handheld when I'm checking mine, good luck
I have a Sena 50s. I will try lower settings on other volumes and let you know, thanks
HLG
