CB Radio
rgc
Jul 21, 2010
53
Gulf Breeze, Fl
While riding this weekend, the passeger could not hear transmission comming in on the CB. After returning home, I looked at the CB volume setting and it say the passenger was "Muted".
I cannot find a reference to this in the owners manual.
Does anyone have any idea how to "un-mute" the passenger on the CB?
Glenn
Glenn
Run up the volume on the right side speaker pod. Make sure you move the squelch then adjust the volume on the rear speaker. I have mine muted right now. I believe, each function has its own volume setting, i.e., intercom, cb, radio. Good luck
Thanks ... I just came in from messing around with the machine and realized that was the problem.
Thanks for the input on a problem I created.
I discovered also that the passanger can only adjust the volume to what is currently selected on the radio. I.E. she could not adjust fm music volume because I had "Intercom" selected. Same with CB. "Muted" is just the lowest setting on the volume control.
yrral
