Belt pulley
Jun 12, 2013
27
11
Prospect Park, NJ
Manny
Anyone here have a CSC trike kit? Specifically on a Yamaha Stratoliner. I've been getting a chirping sound. Checked the pulleys and found one loose. Castle nut has not moved because of the cotter pin. There is some side-to-side movement. Belt shows no sign of wear. Concerned about damage to the splines. Any help would be appreciated.
Manny, maybe you should post question under Yamaha trike section.
Did you speak to your dealer to see what he thinks?
Good luck.
Rosy
My roadstar has little white rollers by the front pulley that chirp when hit by the belt. Your strat probably has them to.
Stitch61
