Trike specific Avon front tire (AV71), on GL1800 >> what air pressure are you running and what results do you have?
orag:
Trike specific Avon front tire (AV71), on GL1800 >> what air pressure are you running and what results do you have?orag:
Loose your thread, down the page further...: http://www.triketalk.com/forum/threads/25596-Update-Avon-Cobra-Trike-tire
I'm running 42 psi. Handles well, and the road noise is way less than oem. I'll lower it to 40 soon, just for comparison.
Sadly I ordered mine from Chapparral motorsports May 4th and Im still waiting.They told me a shipment was coming in May15th,well the 15th has come and gone. Im really disappointed on this one.
They are available from CRT
http://www.cedarrapidstire.com/category/14722/av71-cobra-avon-motorcycle-tires
Make sure it's the "TRIKE ONLY" tire. TRIKE is embossed on the tire.
EXACTLY!!!!
I did not see the Trike tire listed on that site.
It is there.
See details
Avon AV71 COBRA TRIKE MOTORCYCLE TIRES
SKU: 90000020646
BRAND: Avon
TYPE: TL (Tubeless)
POSITION: FRONT
SKU: 90000020646 Snakeskin sidewall treatment complements the Cobra logo and tread design; truly a unique custom look. Fits everything from Valkyries to Customs. Advanced Variable Belt Density (A-VBD) rear construction uses a densely wrapped belt in the center of the tire for stability, wear and mileage, the belt...
<tbody>
</tbody>
Our price: $177.22
<form name="orderform_148216_1414657149" style="margin: 0px; padding: 0px; position: static;" action="https://www.cedarrapidstire.com/cart.php?mode=add" method="post"></form>
Quantity
<select name="amount" style="margin: 0px; padding: 0px; color: rgb(51, 51, 51); font-family: Arial, Helvetica, sans-serif; font-size: 12px; position: static;"> <option style="margin: 0px; padding-right: 0px; padding-bottom: 0px; padding-left: 0px; position: static;" value="1">1</option> <option style="margin: 0px; padding-right: 0px; padding-bottom: 0px; padding-left: 0px; position: static;" value="2">2</option> <option style="margin: 0px; padding-right: 0px; padding-bottom: 0px; padding-left: 0px; position: static;" value="3">3</option> <option style="margin: 0px; padding-right: 0px; padding-bottom: 0px; padding-left: 0px; position: static;" value="4">4</option> <option style="margin: 0px; padding-right: 0px; padding-bottom: 0px; padding-left: 0px; position: static;" value="5">5</option> <option style="margin: 0px; padding-right: 0px; padding-bottom: 0px; padding-left: 0px; position: static;" value="6">6</option> <option style="margin: 0px; padding-right: 0px; padding-bottom: 0px; padding-left: 0px; position: static;" value="7">7</option> <option style="margin: 0px; padding-right: 0px; padding-bottom: 0px; padding-left: 0px; position: static;" value="8">8</option> <option style="margin: 0px; padding-right: 0px; padding-bottom: 0px; padding-left: 0px; position: static;" value="9">9</option> <option style="margin: 0px; padding-right: 0px; padding-bottom: 0px; padding-left: 0px; position: static;" value="10">10</option> </select>
Buy Now
<tbody>
</tbody>
<tbody>
</tbody>
<tbody>
</tbody>
They are pretty proud of it compared to some of the other dealers, but they don't need to compete when they have it in Stock and the others don't.orag:
Worth every penny.
So, who has this tire for sale -now-. Looked at many sites and see the AV71 listed, but with my luck, they would not send the trike tire.
Got an email from J & P Cycles today telling me they have the tire in stock for $152. Free ground shipping... :xszpv::xszpv:
Worth every penny.
Got mine installed yesterday and you are right ....worth every penny!!!
I have ridden about 200 miles since I got it installed with Dyna beads and 41 PSI. I could tell a difference right away. Smoother ride, way better handling when pushing it through tight curves, no movement in handlebars on road snakes or ripples. It has a LOT more road contact than standard MC tire. It Will be interesting to see tire life but not a biggie for me. When this one wears out I will replace with another!!
The tread depth is only 1/2 of the Bridgestone BT45 and the compound is softer too. If you get half the mileage, is it still worth the extra money ?
I keep the tire pressure 41 pounds. I just finished a 6000 km ride .... Lots of twisties and warm weather. My trike (CSC conversion) handled extremely well ... No sign of tire cupping or other wear!
Right now it is!!! I have never run a BT45 so I really have no way to compare the 2 tires as for as ride and handling, or mileage. All I can compare to is the Dunlop stock GW tire that came on the Trike. There is a World of noticeable difference between the two. I have never had good results with stock dunlops, on my 2 wheelers I would pull them right away and run Metzlers , again night and day difference.
If the wear is a problem <12K, I will possibly try a BT45, but for now, I am VERY satisfied.![]()
