Audio Upgrade Info
Biker Bill
Mar 2, 2018
5
3
Yorkville, IL
Bill
I would like to install a ( J L Audio amp) and speakers on my triglide. FLHTCUTG, Does anyone have an instruction thread on how to install these things.
Like a step by step detail, getting the faring off, install of amp, getting old speakers out.
Bill
Welcome to Trike Talk;)
Below is Harley's way of updating a stereo
There are several cautions
BOOM! AUDIO STAGE II FAIRING SPEAKER KIT (FLTR)​
J060162016-06-28
GENERAL
Dealer installation is recommended.
Kit Number
76000594A
Models
For model fitment information, see the P&A retail catalog or the Parts and Accessories section of www.harley-davidson.com (English only).
Installation Requirements
Amplifier Kit (part number 76000523).
FLTRUSE models only: Separate purchase of harness (part number 69200489) and harness interconnect (part number 69200714) is required.
Loctite[SUP]®[/SUP] 243 Threadlocker and Sealant - Blue (Part No. 99642-97).
NOTE
DO NOT mix Stage I and Stage II speakers on the same vehicle.
These speakers are for use ONLY on 2014 and later Harley-Davidson audio systems. Using these speakers on 2006-2013 Harley-Davidson audio systems WILL permanently damage these speakers. Using these speakers on 2005 or earlier Harley-Davidson audio systems WILL permanently damage those systems.
NOTICE
Radio EQ MUST be updated by a Harley-Davidson dealer BEFORE operating the audio system. Operating the audio system prior to radio EQ update will IMMEDIATELY damage the speakers. (00645d)
Radio EQ update using the Digital Technician[SUP]®[/SUP] II diagnostic tool is:
  • Recommended before speaker INSTALLATION
  • Required before audio system OPERATION.
  • Only available through authorized Harley-Davidson dealers.
WARNING
Rider and passenger safety depend upon the correct installation of this kit. Use the appropriate service manual procedures. If the procedure is not within your capabilities or you do not have the correct tools, have a Harley-Davidson dealer perform the installation. Improper installation of this kit could result in death or serious injury. (00333b)
NOTE
This instruction sheet refers to service manual information. A service manual for this year/model motorcycle is required for this installation. One is available from a Harley-Davidson dealer.
Electrical Overload
WARNING
When installing any electrical accessory, be certain not to exceed the maximum amperage rating of the fuse or circuit breaker protecting the affected circuit being modified. Exceeding the maximum amperage can lead to electrical failures, which could result in death or serious injury. (00310a)
NOTICE
It is possible to overload your vehicle's charging system by adding too many electrical accessories. If the combined electrical accessories operating at any one time consume more electrical current than the vehicle's charging system can produce, the electrical consumption can discharge the battery and cause damage to the vehicle's electrical system. See an authorized Harley-Davidson dealer for advice about the amount of current consumed by additional electrical accessories or for necessary wiring changes. (00211c)
The purchase of this kit entitles you to a specially developed sound equalization software that is used with the Advanced Audio System. This unique equalization was designed to optimize the performance and sound response of the BOOM! Audio fairing lower speakers. If this kit is not installed by a Harley-Davidson dealer, this special equalization software is available without charge from any dealer through Digital Technician II. Dealer labor rates may apply for the upgrade procedure.
This amplifier requires up to 8 amps more current from the electrical system.
Kit Contents
See Figure 4 and Table 1.
PREPARATION
WARNING
To prevent accidental vehicle start-up, which could cause death or serious injury, remove main fuse before proceeding. (00251b)
  1. See the service manual. Remove main fuse.
REMOVAL
  1. Remove windshield. Remove outer fairing. See the service manual.
  2. Remove the fairing speaker grille assemblies. See the service manual.
  3. Remove the fairing speakers.
    1. Remove four screws securing speaker to enclosure.
    2. Hold speaker away from enclosure. Disconnect wires. Remove speaker.
    3. Repeat on opposite side.
    4. Discard speakers.
INSTALLATION
1.See Figure 1. Attach the speaker harness connectors (1) inside the speaker enclosure (2) to the spade terminals on the back of the woofer (3). Different size spade contacts prevent improper assembly.
2.Position the speaker over the opening in the speaker enclosure.
NOTE
The letters "A" and "B" stamped on the outer rim (6) of the speaker.
  • For the left speaker, rotate so the letter "B" is at the bottom.
  • For the right speaker, rotate so the letter "A" is at the bottom.
3.Position the midrange speaker mounting assembly (4) over the woofer. Rotate the midrange assembly to align the mounting holes with the woofer. Position the wires at the top of the midrange mounting ring.
4.Fasten the woofer and midrange speakers to the enclosure with four screws (5). Tighten to 1.6–2.3 N·m (14.2–20.4 in-lbs).
<tbody>
</tbody>
1Speaker harness connector (2)
2Speaker enclosure (2)
3Speaker assembly, midrange/woofer (2)
4Midrange mounting assembly (2)
5Stamped letters
6Screw (8)
<tbody>
</tbody>
Figure 1. Woofer Speaker Installation
NOTE
  • The tweeter/speaker grille assemblies are side-specific. The right grille has the text "BOOM! AUDIO STAGE II" to the right of the tweeter housing. The left grille has no text.
  • To ease the midrange to tweeter lead connection in Step 5a, slide back the jacket over the female terminal. Connect the terminals. Slide the jacket forward over the connected terminals.
  1. See Figure 2. Install grille assembly (1):
    1. Connect the two individual leads from the midrange speaker to the tweeter leads on the speaker grille.
    2. Verify that the rubber gasket (2) is in place around the perimeter of the grille. Check that the two clips (3) are in place on the grille tabs (4). Replace components if damaged or missing.
    3. Insert the tweeter wiring and connector into the space between the upper inboard corner of the inner fairing speaker opening and the speaker housing.
    4. Engage tab (4) into the outboard side of the speaker opening.
    5. Engage the grille retainer clips in the slots (5).
    6. Push on the grille in each retainer area until an audible click is heard.
    7. Repeat on the opposite side.
1Grille assembly (2)
2Gasket
3Clip (4)
4Tabs
5Slot
6EQ update label (2)
7Harness
8Tweeter/Midrange speaker assembly (2)
<tbody>
</tbody>
Figure 2. Speaker Tweeter/Midrange and Grille
  1. FLTRUSE models: Install rear speaker interconnect harness (part number 69200714) and rear speaker jumper harness (part number 69200489), each purchased separately. The rear jumper harness connects the rear speakers to the fairing amplifier.
    1. Locate the rear audio [162] beneath the passenger backrest and disconnect [162].
    2. Connect [162A] and [162B] to the mating connectors on the rear speaker interconnect harness.
    3. Connect the four-way [162A] on the rear speaker jumper harness to the four-way [162D] on the interconnect harness.
    4. Use a cap to plug the unused four-way [162C] on the interconnect harness.
    5. Route the rear speaker jumper harness [162B] along the wiring caddy to the fairing amplifier. Becoming connection [313] for FLTRUSE model fairings.
  2. See Figure 2. ALL models: Position harness (7) inside inner fairing.
  3. All models except FLTRUSE:Connect the four-way Molex socket connector [313B] of the Y-harness into the amplifier harness rear speaker output socket [313]. FLTRUSE models:Connect the four-way Molex socket connector [313B] of the Y-harness into the amplifier harness rear speaker output socket [162B].
  • The Y-harness connectors are labeled "RH" or "LH" (right side or left side as viewed from the rider position). Or, match the wire colors of the Y-harness to the speaker wire colors. Route each leg of the harness to the correct speaker.
  1. Plug the connectors into each speaker.
WARNING
Be sure that steering is smooth and free without interference. Interference with steering could result in loss of vehicle control and death or serious injury. (00371a)
  • Make sure that wires, harnesses or lines do not pull tight when handlebars are turned fully to left or right fork stops.
  1. Verify that steering is smooth and clear from stop to stop.
1Left fairing speaker
2Left fairing speaker
3Amplifier, fairing (purchased separately)
4Tweeter midrange [313]
516-way rear audio [162]
6Interconnect, CVO only, (part number 6920714)
7Jumper, CVO only, (part number 6920489)
<tbody>
</tbody>
Figure 3. Fairing Speakers, Amplifier and Approximate Connection Locations
COMPLETION
NOTE
To prevent possible damage to the sound system, verify that the ignition is OFF before installing the main fuse.
NOTICE
  1. See the service manual. Install main fuse.
  2. Have a Harley-Davidson dealer update the radio EQ using Digital Technician II.
  3. Turn the ignition ON, but do not start the motorcycle.
  4. Refer to the BOOM! BOX INFOTAINMENT SYSTEM section of the owner's manual. Turn the radio ON. Make sure that all speakers are working and front/rear fader function is operating correctly. If not, check speaker wiring. Understand that buzzing, squeaks and rattles could be heard until outer fairing is installed.
  5. See the service manual. Install outer fairing. Install windshield.
IN USE
Avoid direct contact with speaker grilles by a pressure washer. Damage to speakers can result.
SERVICE PARTS
Figure 4. Service Parts, BOOM! Audio Stage II Fairing Speaker Kit (FLTR)
Table 1. Service Parts
Item
Description (Quantity)
Part Number
1
Speaker assembly (woofer), fairing (2)
76000525
2
Speaker assembly, midrange (2)
76000606
3
Screw (8)
10200376
4
Tweeter/speaker grille assembly (left) (includes items 5-6)
Tweeter/speaker grille assembly (right) (includes items 5-6)
76000595
76000596
5
  • Gasket (left)
  • Gasket (right)
76000456
76000455
6
  • Clip (2)
12200025
7
Wire retainer, adhesive back (2)
69200342
8
Cable strap (2)
10065
9
Wire harness, tweeter/midrange speaker
69200925
<tbody>
</tbody>
Wiring Diagram Information
Wire Color Codes
For Solid Color Wires: See Connector/Wiring Diagram Symbols (Typical) . The alpha code identifies wire color.
For Striped Wires: The code is written with a slash (/) between the solid color code and the stripe code. For example, a trace labeled GN/Y is a green wire with a yellow stripe.
See Connector/Wiring Diagram Symbols (Typical) . Brackets [] indicate connector numbers. The letter inside the brackets identifies whether the housing is a socket or pin housing.
A=Pin: The letter A and the pin symbol after a connector number identifies the pin side of the terminal connectors.
B=Socket: The letter B and the socket symbol after a connector number identifies the socket side of the terminal connectors. Other symbols found on the wiring diagrams include the following:
Diode: The diode allows current flow in one direction only in a circuit.
Wire break: The wire breaks are used to show option variances or page breaks.
No Connection: Two wires crossing over each other in a wiring diagram that are shown with no splice indicating they are not connected together.
Circuit to/from: This symbol indicates a complete circuit diagram on another page. The symbol is also identifying the direction of current flow.
Splice: Splices are where two or more wires are connected together along a wiring diagram. The indication of a splice only indicates that wires are spliced to that circuit. It is not the true location of the splice in the wiring harness.
Ground: Grounds can be classified as either clean or dirty grounds. Clean grounds are identified by a (BK/GN) wire and are normally used for sensors or modules.
NOTE
Clean grounds usually do not have electric motors, coils or anything that may cause electrical interference on the ground circuit.
Dirty grounds are identified by a (BK) wire and are used for components that are not as sensitive to electrical interference.
Twisted pair: This symbol indicates that the two wires are twisted together in the harness. This minimizes the circuit's electromagnetic interference from external sources. If repairs are necessary to these wires, they should remain as twisted wires.
1Connector number
2Terminal code (A=pin, B=socket)
3Solid wire color
4Striped wire color
5Socket symbol
6Pin symbol
7Diode
8Wire break
9No connection
10Circuit to/from
11Splice
12Ground
13Twisted pair
<tbody>
</tbody>
Figure 5. Connector/Wiring Diagram Symbols
Table 2. Wire Color Codes
ALPHA CODE
WIRE COLOR
BE
Blue
BK
Black
BN
Brown
GN
Green
GY
Gray
LBE
Light Blue
LGN
Light Green
O
Orange
PK
Pink
R
Red
TN
Tan
V
Violet
W
White
Y
Yellow
<tbody>
</tbody>
1Tweeter midrange [313B]
2Left side tweeter midrange connector [LH]
3Right side tweeter midrange connector [RH]
<tbody>
</tbody>
Figure 6. Tweeter Midrange Fairing Wire Harness
Welcome to Trike-Talk Bill.........:wave4:I think Jack has you coved....:clapping:
Let us know how you made out on your upgrade...........
welcome aboard moving thread to Tri Glide forum this one is for posting problems.
Audio rebuild
Thanks for the reply, how ever I am not using any "Harley" parts for this audio build. I was looking for instructions on "how to remove the faring, speakers etc from a Triglide" I did my own work on my Ultra two wheeler but then the whole system wasn't like it is with the new Harley set up?
This is a neat site.
Bill
J060162016-06-28
GENERAL
Kit Number
76000594A
Models
NOTE
NOTICE
WARNING
NOTE
Electrical Overload
WARNING
NOTICE
Kit Contents
PREPARATION
WARNING
REMOVAL
INSTALLATION
NOTE
5Stamped letters
6Screw (8)
NOTE
2Gasket
3Clip (4)
4Tabs
5Slot
7Harness
WARNING
COMPLETION
NOTE
NOTICE
IN USE
SERVICE PARTS
Item
Part Number
1
76000525
2
76000606
3
Screw (8)
10200376
4
76000595
76000596
5
  • Gasket (left)
  • Gasket (right)
76000456
76000455
6
  • Clip (2)
12200025
7
69200342
8
Cable strap (2)
10065
9
69200925
Wire Color Codes
NOTE
1Connector number
3Solid wire color
4Striped wire color
5Socket symbol
6Pin symbol
7Diode
8Wire break
9No connection
10Circuit to/from
11Splice
12Ground
13Twisted pair
ALPHA CODE
WIRE COLOR
BE
Blue
BK
Black
BN
Brown
GN
Green
GY
Gray
LBE
Light Blue
LGN
Light Green
O
Orange
PK
Pink
R
Red
TN
Tan
V
Violet
W
White
Y
Yellow
Figure 6. Tweeter Midrange Fairing Wire Harness[/QUOTE]
Gwtrike
