Anyone using the HD Cool Flow Fan to Reduce M8 Heat
Mar 20, 2018
948
1,035
Saint Louis, MO
Jeff
Is anyone running with the MoCo's CoolFlow Fan (PN 26800121)? I know it is bargain priced at $299.95. I know about the $29 air deflectors. Just wanting feedback on the fan from anyone using it.
I think a lot of the heat is coming from the catalytic converter rather than the cylinder.... of course the two in combo are the real issue. Not sure what options exist (if any) for modifying the catalytic converter location. But trapping heat from the converter above the tranny seems like something that could promote excessive heat at the rear cylinder.
So.... anybody running with the fan? Does it improve the heat situation on the M8?
$300.00 bucks plus dealer activation? Don't seem like much of a bargain to me.Also note that silly device takes up valuable free space around back of the rear cylinder thats used for air flow. No thanks.
I have one on my 2017 Freewheeler. I had it installed by Doc's HD in south St. Ĺouis county.
I agree the heat is coming from the catalytic converter. It pulls the heat away from that area & directs it toward the ground & it definitely helps.
The fan is integrated with the FW speedometer LCD display & as you toggle the 3-way switch, it goes from auto to off to on. It reads in the display "fanauto, fanoff & fanon". I normally leave it in auto, but if I use on, I do not hear it with the motor running.
Between this fan, the DK Customs 1.5" tank lift & Lucas full synthetic high performance motorcycle oil, I am running cooler. I also enabled the EITMS system on May 1st.
Be advised, there are, I believe, 3 different P/N's for the fan, so make sure you get the correct 1.
Thanks Michael.... My ride and MANY parts come from Doc's and yep.... I saw the various models. Old Road Dog Mike has a point in trying to keep the area behind the rear cylinder uncluttered
Thinking about the new "move the catalytic converter" set up to address the problem rather than the symptom + a form of air flow/cooling management (Cool Fan, Oil Cooler Fan, Love Jug Fan, liquid nitrogen cryo freezing alien gas attack methods, fire suit pants.... etc.) Thanks for the feedback
To be honest with you, I probably would not of bought it, my son got it in CA from the dealer I got the trike from & sent it to me. Every other dealer wanted more to install it & Doc's did it for the best price & did quality work, so I picked them to be my dealer. I have done all other work.
It is the best approach. Doc's is not really in to doing things other than selling the bikes and servicing them these days. So I do most everything on mine myself as well. Its more fun that way anyhow. I have been going to Docs since 1976. I knew Ralph well and Patty a little. But in those days they helped you work on anything. They helped me a lot with my 47 servicar.... ah the good ole days :Dorag:
My opinion, worth .02 ,
Sooner or later a full liquid cooled motor will be born. It will reduce the amount of warranty heat issues HD has , that expense can go into the redesign. The long run, happier customers and better sales. They just halfto admit the air cooled era is done ✅
My opinion ,worth .02 ,
That is a good point
Then HD can increase power also
The Water cooling can handle the heat with out losing power
This will make the EPA happy also
I wonder how long it will take to fully roll this out
IMO they cannot make a much bigger air/ oil cooled V Twin with out creating the added killer heat problem
This may disappoint some purists IMO
  • Like
Reactions: MDO
The current service manager, Tim, is a good guy and ex Navy, like myself. They do a lot of work with Vets helping to modify the rides for special needs. They also do a lot with 1st responders. Tim spent an hour with me when I 1st went there, talking military & showing me around. I appreciated it. I told him he passed the interview. I have bought filters & my Custom Dynamic LED front turn signal inserts from them & while they were installing the Cool-Flow fan, someone went out and installed them N/C. I know it's a simple job, but it was a nice gesture. They also give a 10% Vet/1st. responders discount on both parts & service, a nice touch also.:cool:
Well yes.Yes the MoCo should do that. Since the Revolution motor sold like turds on a stick at the county fair on a hot day-not that it wasnt a good idea.Somewhere deep in the bowels of Juneau Ave there is a full liquid cooled big inch 45 degree motor with overhead cams.I just know it. But it won't be rolled out till all us baby boomers take the big dirt nap.
I have one on my 23 rg3. An it cuts the heat on my right leg down considerably. And reduce engine heat a tad bit.
I don't feel my '21 Freewheeler as being any hotter than any other Harley I've owned. It hasn't been a problem for me in 31,000 miles. That being said I'd welcome water cooling if they can do it right. My Triumph Thunderbird Storm had water cooling with a radiator up front and you barely noticed it.
I bought the cool fan and had our HD install it. After buying the switches , cables, and all the parts ended up around $600 installed. Didn’t cool it a bit. Only thing that helped were a set of DEI heat shield inserts. Helped a lot.
Boatpaddle
