advice
Assistance
Hey Jack
Once again thank you for your patient and assistance.
I did get the bike in today at the HD. They still said they need to do their own DTC< As soon they take care of it, I should get a call to let me know what's the problem and how long will stay in the repair shop.
will keep you posted
Hey Jack
Good deal Luis, it was good to meet you and I look forward to riding with you. Do post on what Adamec finds wrong, I am sure they will scan it and find the rear brake switch code
Ill sure second that……… your a TRUE biker and FRIEND to all!
Hope you find FAIR WIND and Smooth Sailing , Jack!
Pete
Thanks Pete, This is what we do as bikers, we all have been jammed up at one time and lo and behold it is our brothers and sisters that are there for us
If I did not believe in this I doubt I would still be riding
Luis had a compound problem that took us both down a rabbit hole, but I am pretty sure the diagnostics ( After ruling everything else out, I did a final scan and found what I pretty much suspected, the rear brake light switch) will be confirmed by our local dealer and with the warranty Luis has it should be a win win;)
Assistance
Morning Jack
Well like I promise. The update on the bike is: they replace the Rear Brake Light Switch. I have break light, turn signals. So far so good.
Guess what! Now the LED light stay on. I had to disconnect the connection from the LED to the batt. :xzqxz:
If is not one thing is the other.
Morning Jack
Good deal Luis, 1 thing at a time
Next we will figure out the LED lights when you have time;)
Assistance
End of work today si at 5pm, After will be or better yet trying to find out what Couse the problem with this LED lights.
When I left the shop, the light wasn't on. But soon I stop to refuel the bike, the light blue came on. Even when the engine off. After then, the light continues on until I arrive at home.
Guess the bike is telling me something :Shrug:
Interesting, I still want to find exactly where the installer of the LED lights tapped into the brake light circuit. Once we figure that out for sure it may be as simple as doing a restart of the LED lights, until then I would keep the power to the LED lights off to avoid any unseen problems
Assistance
Hello Jack
what I did so far, I disconnected all wire from LED to the batt. Connected back one wire at time. Still the problem continues.
Now the other issue I have is I cannot connect to the radio. The break light and turn signal are working.
Hello Jack
That is strange. The brake and turn signals should not have anything to do with the Led or the radio, each has its own circuits, unless there is a wire on the other systems that is connected wrong in an existing wire harness
How is the radio connected? I would assume the LED and radio install have a fuse? Or were they both connected @ the battery?
Some radios have a separate constant hot lead to keep the clock and programmed stations alive. If this radio has that feature that hot lead could be the cause for this problem.
Yes, very strange. RADIO: is just two speakers and the amp plus the Bluetooth. Now the amp is connected to one of the wires we saw that it does not make no sense where is connected. The LED, I will re-do the connection. I need to buy a POSI-TAP.
Assistance
Sorry to mention, I do not have a radio. All I have connected is two speakers, amp and a Bluetooth.
I like the Posi Tap connectors
Assistance
Hey Jack, what you up to?
I'm doing some shopping trying to look for the Posi Tap. Is head to find them. Auto parts, Walmart, Lowe's, they don't carry them.
Any way, i wanted to work on the wire on the bike but without the Posi Tap will not be able to do what I ready shared to do connecting the wires.
For you ride it today?
Waiting for the rain to stop, We used to use these in the past but I think the Posi Loc is better
Assistance
Yes, i know of them. Lowe's try to sell them to me. I read that those are not that good when it comes to heat.
Will I'm hey home working as a plumber. Having problem in the master bedroom.
Hope tomorrow will be better weather,
T.
Cline
