AccuRide Roadsmith
Oct 31, 2011
105
9
Pahrump NV
Howard
Has anyone blown an air shock on their Roadsmith? It seems that I have at 25,000 miles on my 12 GW...I noticed a lot of oil resude on the Axe shafts an boots an on the differential cleaned it all up................does the air shock have oil in the shock?....I noticed that the shaft boot had come off of the bottom of the shock on the shaft end............didn't think too much about that....just reinstalled the boot...............but I notice when the bike is in accy mode..............the pump starts up about 7 times in 6 minutes so that makes me believe that the shock is leaking................will be looking into it more tomorrow an calling Doug on Monday morning to get a new air shock..............this has happened on the right side of the trike.......hope it isn't too hard to change out ............. if anyone has any suggestions on how to change the shock sure would be appreciated.....................an was ready to take off for Phoenix in the mornin for a Bbq run............guess it will be another day.............just thankful that I found this at home an not on the road.................not sure when this has happened because I just got back from the Kerrville run which was 3,200 miles..............is there a chance that I could have hurt the air compressor from running so much with out knowing about the problem.........Hisst
They are sending me a set of new air shocks..............had one that blew the seals............found out they have heavy duty shocks an thats going to be the replacement....hisst
El Cabron
