Accuride Loosing Air Pressure
I discovered by accident when I had the bike idling and the Accuride air compressor came on, the bike raised up. When the compressor stopped the bike lowered back down. I thought something was up because the ride was harsher than normal.
I found the air system connectors behind the right tire (must remove tire) and sprayed soapy water and found that a line at a connector was leaking. I trimmed the line but it still leaked so I had to replace the bad connector .
I also modified the system so I could have a visual when the system was working. Probably an overkill on what I did, but I had an unused volt guage/meter. Also I you have a TPMS system installed you'll have an extra sensor cap.
I have attached a schematic of what I did......
  • Motorcycle Wiring 2016 Goldwing 3-29-20.pdf
I've had my trike w/accri supposedly installed for two years now and have never ever heard my compressor come on..............not even once!
I honestly believe that I have paid for nothing to be installed............. I believe my installer screwed me, again.......
Ronnie
Delverc
