acc. light switch 2016 tri glide
Nov 22, 2016
245
131
Groesbeck, TX
James
​Riding in all this rain for a week took a toll. My fog/running light switch drowned push it on and it just pops right back up and no lights. And Harley doesn't sell just the switch, who could have guessed? You have to buy the whole 9 yards for about $89.00. I found a after market for less than $10.00. Only have a question, how do you remove the switch without having to tear the whole thing apart? I need to get it out so I can measure it as they have 3 sizes. Thanks in advance
I have experienced somewhat the same issue, both with my '14 TG and my '17 TG that I had installed the switch kit. When I pushed the switch and it popped right back up, I looked at it really closely and it looked like it never really changed positions to toggle the switch. I carefully used a pair of needle nose pliers to grab the button and pull it up slightly. I heard a failt click, and when I pressed the switch again, Voila! I had operating lights!
Can't guarantee this is the same issue you are having, but in all cases the preindicator was water (don't know why!:Shrug:) YMMV, give it a try.
I took the switch out of the mounting stuff and sprayed it with contact cleaner that is used on elevators then worked it a couple of times and it was healed so I put everything back together and have my lights back. Thanks for the feedback
Deznan
