2015 FLRT right Rear tire wearing more than left tire
Red sport.
60+ Posts
Sep 12, 2019
67
109
Winfield, AL
James
23,000 miles on stock Dunlop, wearing flat, wore looks like about half out L still looks new. running 26 psi. I have search & search to no avail for answers on my Bike went back as far 2012 all talked about what brand of tires & TG wearing on L But, no fix.
Want to hear from other Free Wheeler's 2022. Thanks in advance for replies
OH, they are the original tires. Want to replace because of age But, like to fix the problem. Harley dealer said they have to look at it. $$$.
I could be way off base here, but remember that you have a differential in the rear. Maybe the right side is the primary drive side and, as such, is the one that gets the acceleration wear, whereas the left would not.....
I would look at: tire balance, wheel damage,brake rotor runout, brake caliper, belt alignment, axle alignment, axle bearings. I wouldnt buy new tires until all these things were addressed.
A friend had a 2015 Free Wheeler it did the same thing he put new tires (good year car tires) on it & ended up trading for a TG. don't know how many miles was on it.
The only/best way to know what’s going on with the tires is to have someone who knows what their looking at..Look at it up close and personal..!
1st Pic. is L 2nd is R the one that is wearing more running 26 PSI. 23,000 miles.
View attachment 110456View attachment 110457
The center tread on lower picture looks like overinflation wear
Maybe it's just me, but I don't see anything wrong with either one of them. Looks like plenty of tread left on both.
I think what The OP Is referring to is that one tire has much more wear than the other both rear should wear evenly..
I just checked my tread depth on stock Dunlops with 19K miles. My gauge readout is in 1/32s of an inch. Left tire reads 7 near center and 9 towards the side.
Right tire 6 center and 8 toward side. So both show 1/16” more wear in center. I always run 20psi.
Are the mfg dates the same for each tire?
I guess I always thought a right tire would wear more quickly on any vehicle with an “open” differential, but this is my first trike so maybe not. It would be interesting if others (with a depth gauge and more than 15,000 miles or so) would measure and compare. Helpful hint. I kept my phone handy while measuring in case I needed assistance getting back up.
Just checked mine. 2021 Freewheeler has 9/32" depth with a depth gauge on both rear tires at 16,500 miles.
Why would a right wear faster on an open diff?
My understanding is that, on cars, under acceleration, the pinion is “climbing” the ring gear and twisting the axle assembly up on the right and down on the left. When that happens the right tire unloads you get wheel spin, aka “one tire fire”. I could be way off base especially on how this would apply to trike differentials.
On cars with out positraction and enough horsepower to do burnouts the power goes to the wheel with the least traction and that tire will wear sooner….Tri-Glides don’t have that kind of power to do burnouts …..
TPost
