2015 FLRT Rear Wiring Harness Insert
Freewheeler trailer wiring harness-plug and play
Keystone,
Your premade insert is most likely cheaper than ordering the HD parts and its pre-made. Please post details on it - maker, place of purchase, part number, and price.....
Springman
Just bought a harness to run my trailer. They use the same/similar set up. Plugs in and add the proper plug for the trailer is all.
Ok, all is good. I'll make one or two. Safe travel.
Did Keystone find a vendor that makes this harness?
I spoke with Sandy at Open Road Outfitters. She thinks her electrical supplier will have one within 2 weeks. Maybe a contact from you will confirm that it is for a freewheeler. I've had the same results as you, where two different vendors have sent a harness they thought would work, but did not. Since the Freewheeler has become more popular, you'd think someone would make this part.
FYI.... I just put on a hitch and wiring harness for my Freewheeler. Got them from Open Road outfitters. They have a trailer harness just for the Freewheeler now!!! Saved a lot of time and headaches!!!
Has anyone found a supplier of the 8 pin molex cnnector for rear lighiting?
Seems evevyone sells the 6 pin molex adapter that won't work on my 2016 Freewheeler. Need the 8 pin adapter as seen in the start of this thread. Not into getting all the items from HD but will if I have to.. Bueler?
# 30 and 25 is where the wire harness should pass thru the body from under the seat, I cannot believe this is not stock on ALL trikes I aint paying 85.00 for some thing that should already be there, I have a magnetic LED light hung in my trunk
Freewheeler Hiring Harness Insert - UPDATE
Sub-Harness for 2015+ Freewheeler only (Rear Wiring Harness Insert) from www.electricalconnection.com
cost is $24.95
To Explain. The above is a pre-made insert made like the one I originally built and made in my initial post to this thread.
This unit is again pre-made - and a lot cheaper. SO, I thought this may help some of you out there.
Springmag
Eddienorman
