2015 FLRT Rear Wiring Harness Insert
Sep 30, 2014
369
57
Grafton, OH
Jim
In an effort to keep the stock wiring harness intact and without any splicing or modification, I decided to build an insert harness to power some of the accessories I would like to have on the 2015 FLRT. The insert goes in between the main wiring harness and the rear light wiring harness at the junction located just below the FLRT’s seat (Connectors 7A & 7B on the FLRT Schematics). The following are notes in support of that insert.
Terminal Pin Chart
Terminal 1 on connectors 7A & 7B – R/Y – Accessory Power
Terminal 2 on connectors 7A & 7B – BE/BN – Right Turn Signal Power
Terminal 3 on connectors 7A & 7B – BE – Running Light Power
Terminal 4 on connectors 7A & 7B – BE/R – Brake Light Power
Terminal 5 on connectors 7A & 7B – BE/V – Left Turn Signal Power
Terminal 6 on connectors 7A & 7B – BK – GROUND
Terminal 7 on connectors 7A & 7B – R/BE – P&A Power
Terminal 8 on connectors 7A & 7B – Reverse Indicator Power FLRT (Not Used)
Parts:
HD part number – 72168-07 – Terminal Socket – 8 needed (10 requested)
HD part number – 72469-07GY – Housing (Male), 8 way, Grey – 1 needed
HD part number – 72473-07 – Seal Pin – 1 needed
HD part number – 72169-07 – Terminal Pins – 8 needed (10 requested)
HD part number – 72447-07GY – Housing (Female), 8 way, Gray – 1 needed
Hope this Helps
Just bought a harness to run my trailer. They use the same/similar set up. Plugs in and add the proper plug for the trailer is all.
Keystone,
Your premade insert is most likely cheaper than ordering the HD parts and its pre-made. Please post details on it - maker, place of purchase, part number, and price.....
Springman
I won't call them cheap, but here is where I got mine from. Up until 2013 the electric hook ups were easy and cheap...
Edit: Today I went out to the garage with the intention of doing the trailer hook up. After questioning the vender as to his product actually working on the FLRT and him stating it did I came to find out it will NOT work on the TG. The one he sent only works on the TG. He know understands it won't work. He will replace the part in 2 or more weeks once he gets the new set up from the company that makes them.
Harley sells an accessory 12v socket for the tourpack on the Tri-Glide. It connects to the same socket under the left panel on the Freewheeler. There is a plastic nameplate/plug behind the felt lining. I took out the plate, drilled a hole, notched the hole and passed the 12v socket wire through it. I now have a 7.2v USB outlet strip in the trunk to charge MP3 players, cordless headsets, etc. I also installed a 120v inverter . . . just in case.. Total outlay was under $50.00
Reverse motor circuit breaker
I tripped the breaker and really feel dumb now after seeing what some of you are doing with the electrical system. I am looking at Figure 98 of my owner's manual but I have no clue where the electrical caddy is. I was just about to take the seat off then decided that I should just ask for help.
My car is in the shop so I thought it would be fun to back my trike into the garage. I am not sure if it was too far or if I used the brake too much before letting off of the reverse but I will be more careful from this day forward.
Yes, I am blonde.:)
I fixed it
I found the location on another thread and I also read that someone drives up the driveway and coasts back down to get out so I will do that the next time I don't use my trike garage. Hopefully my car won't be in the shop too frequently.
Air wing LED light wiring
Do you think your harness will run my air wing LED light? I can do the work. Harley wonts to Hrs. labor to do it. Thanks for the post man.
insert for harley Free Wheeler
Keystone,
Springman
I was told bi Harley their was no insert wiring for the Free Wheeler for the trunk for ACC. or add on air wing light? :confused:
Recently, I have got an influx of private message request for the insert I made and data posted herein. Folks I made exactly one; and, I am not interested in making them to sell - that is sort of why I posted the data on making one.
However, I have heard that a firm called "RIVCO Products, Inc" http://rivcoproducts.com/ may make such an item.
Springman
Springman
Also, I have to say that if you are in the market for one, I would try Rivco and see - as I am sure it would be cheaper than ordering the stuff from Harley as I did.......
Springman
Springman
His doesn't fit either. Bought on last day in Sturgis. Still waiting for them to make it right.
2015 Freewheeler rear wiring harness
Thanks for this info, I'm making the harness as soon as the parts come in...
On on another subject I added passing lights using a 2015 road king light bar and cobra passing light housings. Looks awesome...
padded to date:
passenger backrest
driver backrest
LED headlamp,
rear bumper,
detachable windshield,
heated grips,
Vance & Hines 4" slip ons
luggage rack
luggage rack LED Center light
rear chrome tail lamp LED
Front turn signal LED Custom Dynamics
chrome engine heat deflectors... Need to know more let me know....
Rear rack air wing light
I got it done and it works good. Was not hard to do. " Thanks for the info." How I'm looking for a better head light bulb for the big axx head light that's on it, maybe a H4 PIAA ?? I'm not giving Harley 500 bucks for an LED head light.
LED H4
I found an H4 LED Cree light 6000k light on eBay, installed. Had to modify the retainer, works fantastically, and wow, extremely white and bright. Cost: $55.00...
Freewheeler trailer wiring harness-plug and play
Keystone,
Springman
Ok, all is good. I'll make one or two. Safe travel.
Did Keystone find a vendor that makes this harness?
I spoke with Sandy at Open Road Outfitters. She thinks her electrical supplier will have one within 2 weeks. Maybe a contact from you will confirm that it is for a freewheeler. I've had the same results as you, where two different vendors have sent a harness they thought would work, but did not. Since the Freewheeler has become more popular, you'd think someone would make this part.
FYI.... I just put on a hitch and wiring harness for my Freewheeler. Got them from Open Road outfitters. They have a trailer harness just for the Freewheeler now!!! Saved a lot of time and headaches!!!
Has anyone found a supplier of the 8 pin molex cnnector for rear lighiting?
Seems evevyone sells the 6 pin molex adapter that won't work on my 2016 Freewheeler. Need the 8 pin adapter as seen in the start of this thread. Not into getting all the items from HD but will if I have to.. Bueler?
# 30 and 25 is where the wire harness should pass thru the body from under the seat, I cannot believe this is not stock on ALL trikes I aint paying 85.00 for some thing that should already be there, I have a magnetic LED light hung in my trunk
Freewheeler Hiring Harness Insert - UPDATE
Sub-Harness for 2015+ Freewheeler only (Rear Wiring Harness Insert) from www.electricalconnection.com
cost is $24.95
To Explain. The above is a pre-made insert made like the one I originally built and made in my initial post to this thread.
This unit is again pre-made - and a lot cheaper. SO, I thought this may help some of you out there.
Springmag
