I think I might have a corroded wire between the fuse box and the starter. Does anyone know what color wire this might be so I can trace it down.
Already put a new battery in.
Im confused....If you jumped the starter then the engine should have started, How or what did you use to jump the starter..Because usually when you turn the key on and all you hear is clicking it means that the battery bad..But you say you have a new battery:Shrug:...Then again sometimes even new battery's go bad...
Just hear a clicking sound when key is turned.
Manually jumped the starter and it is good.
Checked all the relays and they appear to be good.
