2006 Harley Davidson Dyna Super Glide with Lehman Renegade - Head shake
Will a steering damper help eliminate low speed head shake on my 2006 Harley Davidson Dyna Super Glide with a Lehman Renegade conversion? If so, where would I find the correct damper kit? Thanks for your help.
Skids
First welcome aboard.
Yes a damper MIGHT help, but being that you ride a conversion I would suggest that you check the steering head bearing tightness first. The bearing should be tighter then what is recommended for the bike when it was 2 wheels. The front trees/tire should not have more than one swing thru on the tightness test. Also does your conversion have a raked triple tree? If not it might be something to look into. This web sites owner sells triple trees at about the best price you can get them at.
Thanks to all who have responded to my question. I look forward to doing as suggested
Thanks to all who have responded to my post. I look forward to performing those adjustments as suggested and continued use of this forum.
Skids, if you have any further questions, feel free to PM me.
:welcome:To the Trike Talk Family! FROM SOUTH
attachment.php
Actually, any reference to swing or fall-away as it is called, would be found only in Harley service manual for a two wheeler. If there is any swing with a trike when installing a rake kit, then there is less than the required 35ft lbs of preload.
The exception to this would be if you are running a pneumatic steering stabilizer and using the stock triple trees as this would be the settings called for on a stock, non raked Harley TriGlide, which is not what is being discussed.
Every Triglide installation should include the removal of the stabilizer. No head shake, no stabilizer necessary.
Desertgecko
