Steering Damper Freewheeler
Jun 30, 2025
4
3
Clinton, NY
John
I just bought a 2025 Freewheeler, the steering is so stiff I find it difficult to steer. I had a Suzuki, Lehman years ago and that had no damper that I recall and steered way easier. If I remove the damper from the Freewheeler what will happen, will it be better or worse steering?
The dampener is made by Ohlins and its a high quality unit( and expensive). Your trike is under warranty...you know...
I don't know if it's possible, but could the factory have tightened the stem nut to tight?
I’m sure you have verified proper air pressure. I suppose you could easily raise the front end and temporarily disconnect the damper to check out whether it or something else may be binding.
All new Harley trikes are test ridden more than once. There is nothing binding, its the nature of the machine. Not enough rake, too much trail. There is a cure.
Dragon warrior
