140/70 18 front tire questions for a 2012
pwhoever
Administrator
Staff member
Gold Member
Jul 31, 2016
1,393
1,910
SE Wisconsin
Mike
Right now I have a Bridgestone Excedra G709 tire mounted on the front that the previous owner put in there when it was a 2 wheel. It is a 130/70R18. I had decided to run that one down before replacing it. I'm seeing that the tread depth in center is very close to replacing now. I am very familiar with having rear tires mounted to front rim and that is my plan on this.
The popular choice besides the Avon trike tire (Short supply and very expensive) is the Bridgestone Battlax BT45 in 130/70-18. The load range for that is 63 and since it's now a trike, added weight has automatically been put on it. So I've been brainstorming options for a higher load range.
Looking at the 130/80-18, it ends up being about an inch taller overall so an extra 1/2" to the fender. It apparently does fit although extremely close to fender. I saw many reports though that at highway speeds, the rider can smell a burning rubber smell and that the rear front fender has taken a beating. So that rules out the 130/80. Now I have also seen some positive results with the 140/70 and that has roughly a 1/2" overall height difference and roughly 1/4" to the fender. So that sounds positive.
The load range on all the 130/70-18 tires I have found is 63 so 600lbs. The load range I am finding on the 140/70-18 is 67 so 677lbs. I like the sound of that.
In the 140/70-18 size, I have found the Battlax BT45 rear, load range 67. Now interestingly, Bridgestone also makes a radial rear tire in that size which is the Battlax BT54 140/70R18 and also has a load range of 67.
So has anyone here tried a 140/70-18 tire on the front of their 01-17 GL1800 and if so, how did you like it? And then the next obvious question is bias ply or radial, and why? I have found the radial at about $30 more than the bias ply. If the radial makes more sense, that extra cost could be worth it.
  • Thread starter
  • Moderator
  • #2
Well looks like I'm going to be the guinea pig I guess. I just ordered a Kenda K671 rear tire in 140/70-18 from Cyclegear and it's set to be shipped to my house. The price was pretty reasonable so if it doesn't work, I'm not out of pocket too much. It has a load range of 67 and speed rating of H so up to 130mph. I went through Cyclegear because they will mount the tire for $30 if you buy it from them. Otherwise it's $60. The closest is just over 40 miles away so not too far. And that's about as cheap as I can find any where to have a tire mounted locally.
It will be probably be a while before I receive the tire and can get it mounted but will update as I get some rides in.
Just some further babbling... Tread depth on the Avon AV91 trike tire is only 4.7mm or roughly 6/32". The BT45 shows a tread depth of 9/32". The Kenda shows a tread depth of 6mm so roughly 8/32". All the numbers for the Kenda look good as an option so fingers crossed it works out.
Mike I love it when you post to yourself. You only gave anyone a little over 9 hours to respond. LOL
Really I like your deductions.
As far as Bias vs Radial in a TRIKE application, the only difference because the trike doesn't lean is the side walls are stiffer on the Bias tire.
With the curved footprint and lack of leaning there should be little difference in grip and tread wear in my opinion.
  • Thread starter
  • Moderator
  • #6
The Bridgestone front tire is a BT46 now
That is correct. The BT46 is actually a 130/70-18 rear tire that gets mounted to the front rim. And they actually do come in 140/70-18, also a rear tire. And then Bridgestone also has a radial rear tire, the BT54 in 140/70R18.
Most tires in the 130/70-18 range are only load range rated at 63 so the same load range when it started out as a 2 wheeler. The conversion alone added some significant weight. I know that the 130/70 have proved themselves capable but I wanted to try something different to give me a bit of a buffer. It seems the only possible option is the 140/70-18 which ends up closer to inner fender by about 1/4 of an inch so I think it will work. The Kenda was cheaper than the Bridgestones. The Kenda has also gotten some really good reviews so I went for it.
Its supposed to get delivered tomorrow and then I just need to get it mounted and drive on it.
  • Thread starter
  • Moderator
  • #7
Halfway there. Tire got delivered today but probably won't get it mounted until early next week. I ended up getting recruited by my daughter to solve a check engine light on her 14 Honda Pilot. A misfire on cylinder 3. And of course Murphy's law kicked in and it hasn't been going as smooth as it was supposed to...
  • Thread starter
  • Moderator
  • #9
Following, please keep us posted!
Regarding your daughters Honda Pilot, some interesting info here to investigate if you haven’t found it already: P0303 No 3 cylinder misfire
Ugh... I was afraid of that. Unfortunately she is under the gun and needs a car to get back and forth to work. I did swap the spark plug coils from 3 and 2, same misfire. I changed out the #3 spark plug, same misfire. The next suggestion was the #3 fuel injector but that dives in a little further than I'm comfortable. Looking at the spark plug, I think that link probably describes what is happening. And for the money to repair the leaking rings, I could buy a used engine for less than what it will cost. I do like the S-VCM (VCM disabler) idea and wouldn't mind giving that a try. Unfortunately I would have to order that online and it has to come from Canada. With the current political situation, it could take a while to get. She doesn't have that luxury and needs her car and with the Check Engine light on, it is a big risk to keep driving it.
And to top it off, when I was going through the troubleshooting, I had also pulled the #2 spark plug to compare it to the #3 plug. When I reinstalled it, I didn't realize the rubber stopper inside the socket had come out and was stuck on the plug. And these plugs are seated down inside long tubes. So not realizing the rubber stopper was still on the #2 plug, I tried reinstalling the coil. It wouldn't go in all the way so I gave it a hard push. Well that rubber stopper pushed down past the face of the spark plug and is now stuck there. I tried everything under the sun including pick set. Nothing, I can't get it out. Luckily it is now down far enough that the coil fits onto the spark plug just fine. The spark plug tube will probably have to come off and that probably involves pulling the cylinder head. Big UGH!!! At least I can ignore that for now until plugs need to be changed again. I kind of hope she decides to trade it in and get something else...
Know what you are going through….
Our daughter had a Chevy truck with a 5.3l V8 with AFM (active fuel management) that deactivates half the cylinders. It started acting up and I had to tear it down to fix it. Then a few thousand miles later the valve body in the transmission started leaking and put it in limp mode. Fixed that. Then it started having problems with the servo motors opening and closing in the heater/air conditioner plenum box. Fixed that. We ended up giving her some money to help her get a newer vehicle.
I know it would ruin it, but on your rubber stopper, can you take a couple really long wood screws and screw them in to it on opposite sides? Then use both hands to pull it out?
  • Thread starter
  • Moderator
  • #11
The problem is that tube is barely wide enough to get the 5/8" socket down in there for spark plug changes. The faces of the spark plug are very close to the wall of the tube so I don't think I could get wood screws down there far enough to do any good. And the spark plug sits about 6" down that tube. And to top it off, cylinders 1-3 are on the firewall side of the motor and you kind of have to work blind with limited space. I need to use 2 3" extensions because a 6" is to long to maneuver. If it is the rings leaking oil, it probably isn't worth the amount it's going to cost to fix and I've relayed that to her and to be prepared that she may have to just trade it in and buy another vehicle. Then I wouldn't even have to worry about the #2 spark plug.
And I really apologize to the members for taking this so far off topic, I didn't mean to.
But funny you mention a Chevy truck with 5.3l motor because that is my other ride. So far, no major engine related issues except for an injector that had to be replaced because of, wait for it! Misfires! That and the starter went out. But I am aware of the potential AFM issues and have been using a Range AFM disabler faithfully which has worked so far. But on my infamous 6 speed transmission, that failed me on a back road down in Alabama about 2 years ago and had to be replaced. Luckily it was still covered by the GM protection plan and a GM reman transmission was installed at no charge to me. I still have a little over 1 year left on the reman warranty but so far so good.
  • Thread starter
  • Moderator
  • #12
An update to this...
Now I know. A 140/70-18 will NOT work. It is only slightly taller than a 130/70 but still too tall. It would probably be ok at the front of the fender. With the G709, I can easily slip my fat fingers in between the tire and underside of the fender. But at the back, the gap is considerably less for some reason. I can very slightly fit the tips of my finger in between the inside of fender and tire. When I installed the rim with the Kenda, there was a very noticeable rubbing on the rear fender and the tire didn't want to move easily. I had it set at 40psi. I even tried airing it down to 35 to see if that would help and it still rubbed.
Oh well. At least I didn't spend a fortune on this tire. And I happened to have a spare front rim in the garage that I cleaned up and had the Kenda mounted on to. So I still have the G709 mounted and put that back on so I can still use the trike. And I found a tire shop that mounted the Kenda for $30. Around here, $60-65 a wheel is the norm. And turns out the owner has 5 different Goldwings from an 1100 to 1500. Unfortunately he isn't too keen on forums.
Now I just need to order a Battlax BT-46 and be done with it.
  • Thread starter
  • Moderator
  • #13
Ok, proper 130/70-18 BT46 ordered and otw. The best price I found through a reputable online outlet was $132.88 from Rocky Mountain ATV online. Free shipping and turns out I had just over $6 in "RM cash" from previous orders so total price including tax was just over $133. Chaparral Motorsports seems like a close second on pricing at $141.97 if you order direct or $143.43 if you order using their Amazon offering.
Rocky Mountain usually ships pretty fast so I should have it in a couple days ready to get mounted.
Mike, I'm curious about your front tire. Is it a Bias Ply or a Radial you are putting on the front? That probably sounds like a dumb question seeing that GL1800s come with radial tires as far as I know. Being new to trikes I noticed that the 2008 GL1800 trike I bought, had a Dunlop American Elite 130/70B18 on the front. It was put on by the HD dealer two years ago and what they run on Harley's I believe. I can't find out the actual mileage the tire was put on, just the date, but I'm curious how many miles I'll get out of it. I don’t feel any odd handling with it that I can tell. I was curious what HD put on their trikes and what I looked at showed they put Bias tires on the front of their trikes.
Just a comment on the Avon Trike tire. One of my friends drives a 2010 GL1800 with a Hannigan Conversion and just changed out his first Avon Trike tire. He says he got almost 25,000 miles out of the first one so he replaced it with another Avon and is sold on them. He rides almost daily and has put about 110,000 on his trike and thinks this is about the best tire he has had.
I think I have about 16K on my Avon - replaced my original tire at about 9 K. Original was OK - just wanted to go to the trike tire.
I like the Avon - however, at the price they are asking (if you can find one) is out of this world. like others, I will go to the BT46 rear - and run it backwards.
I plan to change at the end of this riding season - will probably have 20K or so miles on the Avon.
  • Thread starter
  • Moderator
  • #16
I am putting a bias ply Bridgestone BT46 rear tire on the front. Yes, the GL1800's in the 2 wheel version do use radial tires front and back. I could just replace it with one of the popular radial tires on front rim, however, as a trike, it only uses the center of the tread and it would go through those tires like crazy. Front tire tread depth mostly come with shallower tread depth than a rear tire in the same size. So with trikes, using a rear tire on the front rim is very attractive. But in order to use a rear tire in same size, you have to go with a bias ply. A rear radial tire in the proper size is a unicorn. And actually, not sure if there even is one made.
And I had previously used a Avon Cobra Chrome AV91 Trike specific tire and liked it. But I will say as the miles got stacked onto it, it lost some of the comfort. Avon is the only tire company that made a specific radial trike tire but unfortunately they closed their UK plant back about a year and a half ago. Nova (Avon spelled backwards btw) is the current owner of Avon and has promised to begin producing tires again at plants outside of the UK but that still hasn't happened yet. There are still a few Avon tires available (very few) at a select number of retail outfits but like @cycle7447 mentions, they want stupid money for them and I'm not willing to pay the exorbitant price.
  • Thread starter
  • Moderator
  • #17
Just to add, you will find warnings about mixing radial and bias ply tires. That only comes in to play if you mix them on the SAME axle. That's kind of a non issue on motorcycles as there is only a single wheel on front. A bias ply tire on front axle and a radial on rear axle is completely fine.
Good price, Tires are around $144 on Amazon
Mike, thanks for that explanation on the tires. I know a lot of people have run the BT45s on their two wheelers, I never paid much attention if they were radials or bias ply, now I know.
  • Thread starter
  • Moderator
  • #21
True but $271.99 vs $132.88.... I will stick with $132.88 and accomplish the same thing. And that's pretty close to the cheapest I've seen lately for the Avon. Many places advertise $300+.
I agree ! I run a BT46 on the front of my Trike and on the front of my 2 wheel GL1800. I also have a run flat car tire on the back of my two wheeler. I run the BT 46 in the standard direction. I did run a BT46 on my two wheeler in the reverse direction but could not tell any difference between the reverse and standard rotation.
  • Thread starter
  • Moderator
  • #23
You are in the same train if thought as me. When my previous 07 was still 2 wheels, I ran a Yokahama Envigor run flat on the rear as well. After dark siding my previous GL1500, I was sold and decided I would never ride with a MT on the rear again.
Syl20
