Yamaha Venture Royale Relay Help Needed
I couldn't find anyone who might have one in inventory from my sources.
Can you get it apart and look inside?
I found this one, will it work?
Two wires go to a turn signal flasher and it isn't necessary to use an OEM I think. Perhaps cut the wires going into the OEM unit and use a $5 turn signal relay and put spade connectors on the wires or solder them to the new relay. I used standard or heavy duty relays on all my bike builds; the heavy duty compensate for voltage issues and are used in tow vehicles when pulling trailers which add extra lights.
I will look thank you
Might have too thank you
Trike#1
