Davep
10+ Posts
I have a 2011 Triglide with a 103, the air cleaner cover gets very hot and burns my leg, what would be the best way to solve this?
I always wear jeans, vents are open and it has the cooling wings
Then you should try the floor boards extenders ' You will be surprised on how much difference an inch will make....
That is what she said.....................![]()
Twin cam is the hottest dam motor HD ever built. Plenty of ways to cool it down. But first a compression/leak down test is what I would do.I have a 2011 Triglide with a 103, the air cleaner cover gets very hot and burns my leg, what would be the best way to solve this?
tank lift kit, (went for the Deluxe option) and floorboard extenders just arrived, I'll be installing them tomorrow, my wife insists they aren't going to make any difference, I'm hoping to prove her wrong
made a good bit of difference, but it's still a little too hot, can I put some insulation tape on the inside of the air cleaner cover, or would that cause trouble?
Dave - can you tell us more about your trike? Is it stock or does it have aftermarket exhaust, engine mods, etc? My twin cam ran really hot also. The only solution I found was adding a tuner. They run way too lean from the factory especially with engine mods thrown into the mix.
Check D K Customs for info on how to cool the beast downI have a 2011 Triglide with a 103, the air cleaner cover gets very hot and burns my leg, what would be the best way to solve this?
