2010 Tri Glide Air suspension
Apr 18, 2022
2
BROWNSVILLE
I just bought a 2010 Ultra Classic, Tri Glide. The guy I bought it from didn't know how to do anything on his trike. So now, I have a question, I hear I need to check the psi on my air suspension, but how do I do it? I have a HD pump to do the job, but I don't even know where to look for the fitting. The man before me had it for 12 years and only put 5126 miles on it.
Welcome Mark, try looking under the right side cover. there should be a air valve in the upper right hand corner.
Mark.....Welcome To Trike-Talk.....:clapping:....And yes as Steve says, Theres an air valve under the right side cover....Is the air pump you have an No-Loss air pump, I ask cause with a regular pump you will lose air when you remove it from the valve and your readings/psi's will be way off.....
Hi Mark, :welcome:to Trike Talk
The schraeder valve should be behind your RS cover near the top RH
You have the HD pump, that is a good pump and does not bleed off air when you disconnect it
Have a fun day riding
Somebody offered this tip long ago so I can't take credit for it but it continues to serve me well. I bought the valve stem extension in the link below and have the end of it sticking out from behind the cover. It's barely visible but it makes checking air pressure much easier without having to remove the right side cover. I have never experienced a leak from the extension.
Valve Stem Extension - 42300009 | Harley-Davidson USA
Marks2024
