info
i have a 2009 stallion trike has anyone ever changed the glass cover your gauges.
Bobby I've replaced the whole cluster on the 2008 fiberglass body. There are a couple of brackets on the back that lets you remove the cluster. The cover is plastic so you can use plastic scratch remover and restore the cover pretty well. It's a time consuming job but definitely can be done. If I remember correctly the bolts are 7/16 heads.
thank you for the info going to try and do this this coming weekend thanks again
SOSMentor
